I have just started using AVStoDVD to auther dvds. I use the latest version of AVS2DVD.
I recently bought a HD camcorder which produces many..100+ .mts files. If I add all the files to AVS.. and run authoring..I see two problems:
1. the menu wizard creates many pages with one 16+ tiny menu items on each page. Can I create chapters by time interval? e.g say every 15 mins or 20 mins, Or is there any hack to get only say 4-5 chapters for the entire recording in one single page?
2. I seem to be running into some upper threshold which says that it cannot handle more than x or so titles. Can I tweak something to remove this upper thershold?
Thanks in advance,
Actually it's not AVStoDVD thats makes the limit - it's inherited to the structure of a video DVD.AVStoDVD limit the number of chapters/titles in Menu
Take a look at this:
https://www.videohelp.com/dvd#struct
So, your DVD may have up to 99 Titleset (VTS) - each having up to 99 Titles (.mts files) - with each Title having an (practically) infinitely number of chapters.
However, AVStoDVD creates one Titleset for each of your .mts file with that file as the only Title within the Titleset - which limits you to 99 input files.
What you could do is to use something like tsMuxeR to join your 100+ .mts files into 4-5 files (or you could use an authoring program that handles more than one Title in a Titleset like DVDStyler).
And should you want chapters within these 4-5 Titles press Ctrl+E änd select the "Chapters" tab.
Cheers -
thanks videobruger
Anything that can be done with AVSToDVD to limit the number of chapters in the menu..I get like 7-8 pages of menu with 20+ chapters in each. I woul;d ideally like to get 15 min interval chapters form all the MTS files I add.
Thanks -
Cannot preview titles and chapters
By YonB in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 13th Mar 2010, 15:23 -
How to convert Titles to Chapters
By Psymon007 in forum Newbie / General discussionsReplies: 14Last Post: 11th Jun 2009, 18:20 -
Multiple titles in AvsToDVD
By alhenderson in forum Authoring (DVD)Replies: 15Last Post: 16th Feb 2009, 04:06 -
How to merge several chapters or titles together
By guns1inger in forum DVD RippingReplies: 0Last Post: 26th Dec 2007, 22:25 -
Wrong number of chapters on ripped DVD precludes encoding
By headless chicken in forum MacReplies: 3Last Post: 2nd Sep 2007, 15:26
