(Win 7, 2,8ghz, 4 RAM, 500HD)
I can't access the hidden options in AutoGK. I tried to reinstall AutoGK, Xvid and divx codecs but still cannot see the CTRL-F9 options !
I closed AutoGK and try CTRL-F9 on my desktop, still nothing...
I installed it on my laptop, and "bang"! it works just fine ! What is wrong with my desktop computer ?( Win7 freshly installed a month ago).
Thanks for your help !
And you haven't enabled any fn-key/f.lock on the keyboard so the f9-key is disabled?
You are not alone, https://forum.videohelp.com/threads/305337-AutoGK-CTRL-F9-DOES-NOT-WORK?highlight=autog...hidden+options . No solution though...
Well my friend... after reading your anwser I decided to change my current keyboard (you know the one with a thousand "option keys"...) to a standard one. Guess what... It worked right away ! Ohhh ! Those dam fancy keyboards !
Thank you for help.
Tablet Pc and internet access options
By Moontrash in forum ComputerReplies: 6Last Post: 9th Aug 2011, 06:25 -
GUI for DVD Author- how to forbid access to a 'hidden' bonus video?
By extent in forum Authoring (DVD)Replies: 10Last Post: 19th Jan 2009, 23:42 -
Auto Gordian Knot Hidden Options Error
By Mabbage in forum DVD RippingReplies: 1Last Post: 18th Aug 2008, 15:59 -
AutoGK encoding options
By MyBigToe in forum DVD RippingReplies: 2Last Post: 3rd Mar 2008, 12:47 -
Virtualdub - out-of-bounds memory access (access violation) Lameacm
By kidcash in forum Video ConversionReplies: 1Last Post: 21st Jan 2008, 09:34
