    Aug 2002
    South Florida
    Does this codec pack present any problems with BD Rebuilder or any other programs that you know of?
  2. You should use the recommended and tested (by jdobbs) versions of AviSynth, Haali, and ffdshow linked here:
    http://forum.doom9.org/showthread.php?t=143716
    In which case you wouldn't need Klite, except possibly for single codecs you can install if necessary. You might get away with it (i.e. BDRB might work anyway), but unless some other program won't work with those versions, there's little point. Actually, when I went to Win7 64-bit, the linked version of ffdshow buggered another program, and I eventually found another (untested) version that would work. But not long after, jdobbs updated the recommended version, which works fine with all my programs, including BDRB.
    Good luck.
    Pull! Bang! Darn!
  3. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    No, it doesn't.
    Beware any followup posts claiming otherwise.
    Oct 2005
    666th portal
    No, it doesn't.
    haha! - playground rules, he said so first so it must be true...
  5. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Hahaha, "puss", you're a hoot!
    "By jove! They must be pooping in the paddys!"
    -a western tourist surmised during a tour of the countryside rice fields with no portapots in sight.
    Sep 2011
    fritzi93, which version of ffdshow are you using?
  7. The one at the link above:
    ffdshow_rev3882_20110613_clsid.exe
    Pull! Bang! Darn!
