Ok, i have bought new tv awhile ago and i got an option to insert my USB device to it and watch videos and pictures from it
It works decent.. But theres this one problem. Sometimes the TV wont recognize the video from my USB, it says something like this "No displaying files available"?? First i though the problem was that the TV cant recognize that kind of format. (The video was MP4) but when i tried another MP4 video, it worked. So it cant be about the format cant it? Now i got this MKV video file i want to watch and the TV wont recognize it. Any idea whats the problem? Is it coz of wrong format? or why does it keep doing that? Thx all for listening!
(soz bad english =/ i tried my best)
MP4 is a container -- a box that holds video and audio that may be compressed (or not) with a number of different compression schemes (codecs). It's likely that your TV doesn't support some codecs. There may also be resolution issues. TVs are notorious for limited support of video file playback. You can use a tool like MediaInfo to examine your video files and determine which codecs and what frame sizes are supported
I don't know if this is even possible with MP4 containers, but a lot of MKV files have video and audio with "stripped headers" (MediaInfo will tell you if this is true for your file). If this is also possible with MP4 files then this could be why some files don't play. Only PCs understand how to play files with stripped headers.
The device USB 2861 device could not be opened
By Fabis94 in forum EditingReplies: 5Last Post: 20th Nov 2010, 14:40 -
USB device not recognized
By SIRCOOKS in forum ComputerReplies: 6Last Post: 25th May 2008, 22:38 -
A Good USB Capture Device?
By hech54 in forum Capturing and VCRReplies: 5Last Post: 23rd Dec 2007, 03:23 -
USB device capture
By ramin in forum Capturing and VCRReplies: 1Last Post: 15th Nov 2007, 15:48 -
USB Capture Device
By gruberted in forum Capturing and VCRReplies: 13Last Post: 11th Jul 2007, 14:56
