Results 1 to 14 of 14
  1. Hi I'm a newbie in video converting.
    I used RipBot to convert anime from .avi to .mkv and I found some of the converted videos are out of sync with the audio.
    The problem is the video after the conversion. The original video length is 22:07 but the converted video length is 22:05.
    I tried with other anime and it seems that RipBot keep modifying the lengths of videos and fix them at 22:05.
    How can I solve the problem?
    Post the details from the avi. Use MediaInfo, view->text and copy and paste.
    Or try another all-in-one converter like handbrake or xmedia recode.
    Or try remux the avi to mkv, with mkvtoolnix / mkvmergegui open the avi and make a new mkv. No video and audio reconversion. But if you are doing any resizing, shrinking, embedding subtitles this wont work.
  3. These are the details of the avi:
    Format : AVI
    File size : 353 MiB
    Duration : 22mn 7s
    Overall bit rate : 2 228 Kbps
    Writing library : This file was made by AviUtl 0.99.
    Video
    Format : MPEG-4 Visual
    Format settings, BVOP : Yes
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Muxing mode : Packed bitstream
    Codec ID : DX50
    Codec ID/Hint : DivX 5
    Duration : 22mn 7s
    Bit rate : 2 027 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 23.934 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.276
    Stream size : 321 MiB (91%)
    Writing library : DivX 5.0.2 (UTC 2002-05-16)
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Codec ID : 55
    Codec ID/Hint : MP3
    Duration : 22mn 7s
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Stream size : 30.4 MiB (9%)
    Alignment : Split accross interleaves
    Interleave, duration : 42 ms (1.00 video frame)
    Interleave, preload duration : 41 ms
    So there's no way you can 'prevent' BitRip from changing the video length?
    p/s: Yea, I'm trying to use RipBot to convert the avi into smaller-size mkv. So far I've converted 4 episodes of 300+MB avi into 100+MB mkv
    Mar 2008
    I noticed the frame rate is non-standard:
    What is the frame rate of the converted (out of synch) file?
  5. Thank you davexnet for replying.
    Here's the media info of the converted file:
    Format : Matroska
    File size : 112 MiB
    Duration : 22mn 6s
    Overall bit rate : 706 Kbps
    Movie name : Yu-Gi-Oh! Duel Monsters - Episode 005 - Ultimately Perfect Form, Great Moth_Experiment
    Encoded date : UTC 2012-02-01 12:33:30
    Writing application : mkvmerge v5.2.0 ('I can't explain') built on Dec 29 2011 19:29:57
    Writing library : libebml v1.2.3 + libmatroska v1.3.0
    Video
    Format : AVC
    Format profile : High 10@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 22mn 6s
    Bit rate mode : Variable
    Bit rate : 513 Kbps
    Maximum bit rate : 25.0 Mbps
    Width : 640 pixels
    Height : 480 pixels
    Frame rate : 23.930 fps
    Color space : YUV
    Bit depth : 10 bits
    Bits/(Pixel*Frame) : 0.070
    Stream size : 79.0 MiB (71%)
    Writing library : x264 core 120 r2146 bcd41db
    Encoding settings : cabac=1 / ref=4 / deblock=1:1:1 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=30 / rc=2pass / mbtree=1 / bitrate=513 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=81 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:0.60
    Audio
    Format : MPEG Audio
    Codec ID : A_MPEG/L3
    Codec ID/Hint : MP3
    Duration : 22mn 6s
    Bit rate : 192 Kbps
    Stream size : 30.4 MiB (27%)
    Language : Japanese
    Text
    Format : ASS
    Codec ID : S_TEXT/ASS
    Codec ID/Info : Advanced Sub Station Alpha
    Language : English
    The frame rate is different from the original video (23.930). So does it mean that I can solve my problem if the frame rate is the same? How do I solve my problem?
    Mar 2008
    Try using Avidemux 2.6 to convert the file. http://avidemux.razorbyte.com.au/
    Download and install build 7740.
  7. To convert which file? The original one? I'm confused of how to use it to change the frame rate. Please provide some guideline. Thank you so much
    Mar 2008
    leave the frame rate as is and try to re-convert the original. It's possible the FR is a red herring;
    there may be other issues.
    In general, if the FR is non-standard and you want to watch it on the PC, it's fine.
    However, if you want to play it on an external media player/standalone it is better to
    have it at the proper 23.976/29.97.
    Sometimes some corruption in the source, perhaps only a few frames, can cause a
    a synch problem during conversion.
  9. What should I set in the conversion (using avidemux) so that I won't lose much quality?
    Sorry for the trouble..
    Mar 2008
    Set ouput format to MKV. Set video to mpeg4 AVC. The default setting is pretty good, CRF 20.
    Try with settings 18 to 20. The lower the number, the bigger file and better quality.
  11. Member Shilar's Avatar
    Aug 2006
    I must ask... why are you converting avi to mkv? You do not gain much.
    MKV: Merely Krappy Video.
    Subbers, a request from an avid viewer: Either don't use mkv, or supply avi or mp4 as an alternative.
    For those frustrated with converting MKV: http://www.immortalmusic.net/mkv/
  12. I wanna convert it into mini mkv. This will save alot of space for me >> Gain alot from this.
