I have a 3tb 3.5 western digital hdd that I would like to connect to my LG 55LK520. When I connect it, it detects the drive but says theres something wrong with the usb device, so I thought maybe it didn't detect ntfs formatted drives. Then I connected a 2gb ntfs usb stick and it was fine. So I was thinking maybe the capacity is too be for the tv to handle? Although I dont' think that should be a problem. Has anyone heard of a limit that you can have for usb devices connected to tvs?
Results 1 to 9 of 9
You have to jump through hoops just to hook a drive that size to a PC, there's a good chance the drive is too big for the TV. I'm not sure partitioning it would help, but your best bet is to get in touch with LG tech support and ask what's the largest drive you can use.
I have an LG 32LK330, which shares a manual with the LG 55LK520. Page 55 of the manual says our TVs can only use external HDDs up to 1TB, or USB flash drives up to 32GB. 3TB is too large.
I actually found someone else who has the same tv and he was able to connect a 2tb hdd do it so I formatted the 3tb into 2 1.5s and it worked.
*** Now that you have read me, do some other things. ***
That may be, but even NTFS is not always "NTFS".
Many devices even give up when the standard formatting features were not used (correct cluster size etc).*** Now that you have read me, do some other things. *** -
If someone is technically proficient enough to format their drives using non-standard NTFS features, they are probably smart enough to know better than to try using them with a TV, Blu-Ray player, or media player.
These particular LG TVs obviously do work with USB devices that were formatted with standard NTFS features, as long as the drive or partition is not too large.Last edited by usually_quiet; 19th Feb 2012 at 14:43. Reason: corrected a typo
I wonder if the 2 terabyte limit for MBR partition table has something to do with this. Anything over that size partition must be GUID partition table.
Anyway, I have a 2 terabyte external drive, MBR partition table, and my LG 65LW6500 recognizes it.Pull! Bang! Darn!
Connection help please! HDD Recorder, SKY TV to TV
By sarahholland in forum DVD & Blu-ray RecordersReplies: 1Last Post: 16th Apr 2011, 06:38 -
Connection setup for a STB and HDD recorder
By garyasta in forum DVD & Blu-ray RecordersReplies: 1Last Post: 8th Mar 2011, 22:32 -
t.v. connection problem
By brenda1906 in forum Newbie / General discussionsReplies: 10Last Post: 27th Mar 2010, 07:18 -
HDD swap! Faulty 'Funai HDR-B2735' vcr/hdd/dvdr ... use HDD in a JVC ???
By StuR in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Oct 2008, 12:38 -
Wireless Connection Problem
By StoneColdWhat in forum ComputerReplies: 4Last Post: 7th May 2008, 23:38
