I have a external blu-ray reader where I can rip blu-ray but I can't burn it onto a blank blu-ray. I am try to encode it to where I can watch it but I use vlc Media Player. If I encode to mkv or m2ts it will display the audio fine but i have to move the slider to see the video and the video is only good for a second or less then the picture gets pixelated.
Any advise on how I can view the video better?
I just rip everything to mp4 and import into iTunes. It's great for organizing everything and easy to attach the cover art. My pc has HDMI and it's connected to the TV. I never burn anything to disk. The quality I've been getting since I got Aiseesoft has been amazing.
I find SPlayer portable works well for me. Last time I tried the installed version there was an issue if you assign it as default for file types. But I use portable with no file type assignments and I like it quite a bit. I put a shortcut in SendTo menu to play files via right click.
One down side is it still doesn't support PGS subs. Nothing's perfect.
http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs.
Ripped blu-ray. Now what?
By whoisquilty in forum MacReplies: 5Last Post: 2nd Aug 2010, 18:36 -
Q: about playing a ripped blu-ray
By raptor1015 in forum Software PlayingReplies: 1Last Post: 29th Jun 2010, 12:58 -
Help, can't convert or view VC-1 files ripped from Blu Ray
By Y2Bogus in forum Video ConversionReplies: 4Last Post: 12th Jun 2009, 06:29 -
BLU-RAY Ripped
By pensioner in forum Newbie / General discussionsReplies: 7Last Post: 11th Feb 2009, 23:37 -
Burning Blu Ray from ripped Blu Ray
By ppurdue in forum Blu-ray RippingReplies: 10Last Post: 15th Oct 2008, 20:51
