hello!
I captured the slideshow of a lecture (ie. a flat 2-dimensions object), but I now realized that some the angles are not correct
specifically, I want to move all the picture a bit anti-clockwise and also move the upper part towards the viewer
how can I do such adjustments?
thanks!
You'll have to reencode, for one thing. Do you know any AviSynth? It has filters available to rotate the video and also to adjust the skew (is that the right word?).
http://avisynth.org.ru/rotate/rotate.html
http://avisynth.org/vcmohan/Reform/Reform.html
Ripping with angles
By Dozza in forum DVD RippingReplies: 4Last Post: 18th Apr 2019, 15:54 -
How can add subtitles to dvd with 2 angles
By siopilos in forum SubtitleReplies: 0Last Post: 21st Jul 2008, 17:17 -
Basketball court angles or perspectives????
By wan2no in forum Newbie / General discussionsReplies: 2Last Post: 27th Feb 2008, 02:05 -
Angles using freeware - is it possible?
By Qun Mang in forum Authoring (DVD)Replies: 10Last Post: 5th Sep 2007, 09:27 -
AutoGK mishandling angles
By briansmccabe in forum Video ConversionReplies: 7Last Post: 12th Jun 2007, 10:13
