Hello Folks!
I'm pretty new to the whole video conversion thing. For a project i am working on i have to convert Videos recorded with FRAPS using open source codecs an - if posssible - FOSS.
I work with Ubuntu 10.10 and Win7. I tried VLC, WinFF, Transmageddon, MediaEncoder and Avidemux. But none with satisfying results. The Input files are about 4 Minutes and have 4GB.
Everything i try brings quite big files (about 50MB) with bad quality.
I mainly tried Theora und Vorbis in an ogg container by now. ANY help would be very appreciated! But please no solutions with Codecs that are not open source!
Results 1 to 10 of 10
I already tried ffmpeg2theora using
but the result is of very poor quality with about 40MB for 3 minutes.Code:ffmpeg2theora --optimize --soft-target --two-pass -V 1200 -A 112 --pp vb:a,h1:a,dr:a -x 960 -y 540 'input' -o 'output.ogv'
Try mediacoder with x264 cuda (you can use your graphic card to encode)
*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
If your video is CG follow general rules related to such video - probably poor quality is unavoidable without high bitrate - try MPEG 1 with only I and P frames with fixed Q to avoid video "pumping"
You can also encode to WebM and VP8 format with ffmpeg.
http://www.webmproject.org/
But 50 MB is quite small file size for 4 minutes of video but it depends on resolution, framerate and compression.
Maybe you should increase the bitrate to get bigger files, or reduce resolution and/or framerate to get lower compression.Ronny -
What you are trying to do is well nigh impossible .. unless you travel to the future, when quantum compression wavelet technology is prevalent.
4.000,000 /50 is already a compression ratio of 80,000 to 1. Of course your output is shite, you're trying to squeeze a gallon jar into a teardrop
But you dont say what your source is and what you expect to get out ..
what sort of quality, what sort of use
Methods and results ?? xvid vp8
DVD to avi expect compression of approx 7:1 . this can be stretched to 15:1 but 80,000:1 is beyond your puny human technology.Last edited by RabidDog; 2nd Feb 2012 at 19:00. Reason: granma
DVD is already heavily compressed. 4 minutes of DVD video is approximately 200 MB. 4 minutes of video at 4 GB can be compressed to the same size as 4 minutes of DVD video, no matter of original file size. I do think it is impossible to make it 50 MB with decent quality if resolution and framerate is about the same as DVD and using an efficient codec like VP8 or h.264.
EDIT: Sorry I did a writing mistake which I have now corrected (removed not). Actually I think it IS possible to make it 50 MB with decent quality...Last edited by ronnylov; 9th Feb 2012 at 06:57.
Ronny -
You can think specific numbers here.
Given : 4minutes and 50MB.
Result: 1700 kbps
Size of video for this bitrate should be no bigger then 960x540 or so and still it is going to look like internet video feed or so. It depends on type of video. If there is no noise, clean, perhaps you can try 1280x720. H.264 of course.
Best open source NLE software
By landstake in forum EditingReplies: 42Last Post: 24th Jun 2012, 00:09 -
any open source vReveal alternatives?
By deadrats in forum ComputerReplies: 2Last Post: 12th Oct 2009, 07:16 -
Do you donate to open source software?
By yoda313 in forum PollsReplies: 15Last Post: 28th Aug 2009, 19:15 -
What's the best Open Source equivalent to Nero?
By OM2 in forum Newbie / General discussionsReplies: 7Last Post: 1st Feb 2009, 14:39 -
A proposal for Open Source HD-DVD
By hddvdrebel in forum DVD & Blu-ray PlayersReplies: 8Last Post: 27th Mar 2008, 21:12
