Hey all,
I just used EAC today to rip a CD. Just FYI, it's a more complete release of the "It" soundtrack.
Anyway, on many of the tracks I hear occasionally clicking. When there's a quieter moment or the track is fading out, it sounds almost like a drummer clicking his sticks together.
Is it possible that a poor job ripping the CD might cause this or *shudder* is it truly on some of the tracks?
Thanks,
Justin
Results 1 to 11 of 11
Eek! Yeah, I know that EAC is a staple to many, many people. I'm just not sure what's causing what I'm hearing.
If it might be significant, I should mention that I was listening to the FLACs I created, rather than waves or MP3s. -
I don't have the log, unless it's stored somewhere I wouldn't know of.
The log isn't saved unless you actually tell the program to do so.
Press F9, then click on the "Tools" tab. Check the boxes next to "Automatically write status report during extraction" and "Append checksum to status report."
Try ripping the CD again. Click on Action, then Test and Copy Selected Tracks. It'll rip the disc twice (once as a test, once in the format of your choice) and if the CRCs match then the rip was good.
Another possible problem is that your DVD drive is incorrectly configured. Press F10, then click on the 'Drive' tab. Press the "Autodetect read commands" button and wait a bit. Then go to the Extraction Method tab and click on the "Detect Read Features" button.
You can also use the Autoconfigure option to have EAC fix all these issues if they exist. Hope that helped.
Edit: And as an EAC fan, I can admit that the program has a lot of bugs that need to be worked out. It's good but it's not ... perfect. -
I have used EAC for many years, and a few years exclusively at least!!
I have never had an issue or noticed any bugs, i am not saying there are not any, i just have not come across them.
I use EAC in AccurateRip mode, to copy cd's to cdr's, to WAV on my HDD and to FLAC on my HDD and have never had any problems.
Years ago i used to be a big fan and use another program, but i'll be damned if i can remember the name of it.....
I know hech54 know's the name of it, you know it, because i have seen you (hech54) recommend it over EAC more than a couple of times
5.1 mix gone wrong. Did the "pros" do a poor job?
By takearushfan in forum AudioReplies: 33Last Post: 21st Nov 2009, 21:34 -
Ripping subs from a poor recording?
By bmwracer in forum SubtitleReplies: 0Last Post: 5th Dec 2007, 15:37 -
Pops, Clicks when ripping DVD
By coyotewrw in forum DVD RippingReplies: 1Last Post: 14th Nov 2007, 19:57 -
DVD Ripping-poor result
By pauldb in forum DVD RippingReplies: 8Last Post: 6th Aug 2007, 20:31 -
Ripping of Commercial DVD -- poor result
By pauldb in forum DVD RippingReplies: 2Last Post: 30th Jul 2007, 10:04
