Results 1 to 23 of 23
  1. hello
    I have a laptop and I installed cs4 on it (32 bit)
    it is running very slow
    (it is ok with one single time line, but i need to work with 3 timelines and it moves like a snail or not at all)
    my computer ability is attached in a pic.
    helppppppp pleaseee...
    thanx
    Oct 2005
    666th portal
    what type of video? also, laptops are never a good idea for editing. yours is only a pentium 2 core, not very speedy. a tower with good cooling 4 hard drives, gtx570 video card or better and an an 8 threaded i7 might be a good purchase. if you can afford cs4, an editing station should have been purchased also.
  3. thank you.
    those are HD files.
    it is a trial version of CS4.
    (I don't have enough to buy a new machine)
    isn't there some program that jams it - and if I will take it off it will allow me to edit properly?
    or is it a lost case?
    Oct 2005
    666th portal
    no the computer doesn't have the cpu or gpu for editing. especially if you are trying to edit avchd file. about all you could try is to convert the videos to an easier to edit format, maybe use a lossless codec. but then you probably don't have the hard drive space to hold them.
  5. actually, this is a very good idea.
    are you saying that if the files are AVI or MPG, it might do the job after all???
    (or an other file type you'd recommend that will allow the processing)
    Oct 2005
    666th portal
    an intermediate codec conversion may help ease the load. some lossless ones are - dnxhd, huffyuv, lagarith, etc. the file size will be 10 - 100 times as big though.
  7. true, I will need more room for that.
    Thank you very much for the help!!!
  8. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Switch to Sony Vegas Movie Studio and it will run much faster.
    Anything Adobe is bloatware. They use some Macromedia-type fakakkta GUI that eats up all the ram just to start up, then the user's work product gets sent to page file memory (HD virtual memory).
    Some people think the faster PC you need means the software must be really powerful, but actually well written efficient software doesn't need so much horsepower.
    I don't know how Adobe managed to put out a Mac version of Premiere either, unless it's a stripped down version. I guess the Macheads wouldn't know anyway, right? Hehehe, just kidding, I LOVE those little Mackies, they're so cute.
    But compared to PC's, Mac's are even less capable, that's why they had to switch to an Intel chip in the "Power" Macs, but they're still underpowered in hardware terms.
    For more info Google: ADOBE BLOATWARE
    Or to see all the complaints on the Adobe forum: http://forums.adobe.com/thread/428133
    Hope this helps.
  9. Member turk690's Avatar
    Jul 2003
    ON, Canada
    IMHO, the biggest sin this laptop is guilty of will not be that it's Pentium or 32-bit, or that Premiere CS4 is called on to squeeze it, but that I bet there's only ONE wretched hard drive groaning under all that work. Maplewood, find out if that laptop has eSATA; attach an external HDD to this port, and put all media files in this HDD. This step alone should alleviate some of the slowness. No, USB drives DON'T count, NEVER will. But why stop there? Anyone only even slightly serious about Premiere and expects it to live up to its touted abilities should, with very few exceptions (ALL of these with that magic eSATA port), not be caught dead using it on a laptop.
    For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
  10. Ok
    I am now running on a bran new pc
    Windows 7
    Service pack 1
    AMD phenom(tm) II X4 840 processor 3.20 GHz
    Memory: 4.00 gb
    64 bit operating system
    And it stil can not work more than one time line
    Something is really wrong here!!!!!!!!
  11. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    use mediainfo on a typical source file in text mode and copy/paste the results here.
  12. You mean right click on one of the sources while I'm in premiere?
    It has no "mediainfo" option on right click
  13. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    https://www.videohelp.com/tools/MediaInfo Under View, select text and post result.
    I suggest you downsize your video to 960x540 or 848x480 MPeg2 to fit that CPU and hard disc. That will give you some idea how the program works.
    If you invest in a new laptop, make sure it has i5/i7 CPU with two internal hard drives or a single drive + an eSATA port. A tower would be faster and cheaper.
    http://www.kiva.org/about
  14. here are the stats:
    General
    Complete name : C:\projn\00006.MTS
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 3.99 GiB
    Duration : 26mn 23s
    Overall bit rate : 21.7 Mbps
    Maximum Overall bit rate : 24.0 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Format settings, GOP : M=3, N=12
    Codec ID : 27
    Duration : 26mn 23s
    Bit rate mode : Variable
    Bit rate : 20.4 Mbps
    Maximum bit rate : 20.9 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.394
    Stream size : 3.76 GiB (94%)
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : 129
    Duration : 26mn 23s
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Delay relative to video : -384ms
    Stream size : 72.5 MiB (2%)
  15. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    well to repeat myself you need a high end computer. i7 2600k 8 threads, 64bit os. 16gb ram, top notch video card gtx570 or above, at least 3 fast hard drives. even then editing 1080 avchd is slow going.
    and adobe cs5.5
  16. it is a trial version of CS4.
    The CS4 trial version doesn't even support AVCHD or h264 blu-ray, how are you opening it ?
    As aedipuss says, you need faster hardware, more drives
    Or you can do what people have often done in the past; either a proxy workflow, or use an easier editing intermediate like cineform
  17. why would you answer something that is not true?
    1.
    a trial version is the exact program like the purchased one.
    where's the reason in that? you get a full version and it is a trial - But you can enter a serial number and it turns imediatly to a non trial version. meaning- you had the full version But for a limited time.
    2.
    as I said - I am working on a stripped bran new powerful tower
    (and It has a legit premiere cs4)
    it still does not play more that one track
    help!
  18. + the guys that lend me the work station can go cs5 - no problem.
    the question is will this sort the issue?
    (or shoul I go Avid and thats it?)
    here's a picture of the system Im on now
  19. Member edDV's Avatar
    Mar 2004
    Originally Posted by maplewood View Post
    Ok
    Windows 7
    Service pack 1
    Memory: 4.00 gb
    It is the h.264 codec that consumes your CPU power. On that machine, the conversion of video to Cineform intermediate codec (Cineform Neoscene $129)* should be enough to run two simultaneous video streams in preview without pegging the CPU**.
    Nest issue, you haven't explained the disk system configuration on the AMD machine. First issue is to separate the video drive from the OS drive. You will get better performance if a third drive is added so that each video track plays off separate drives. This minimizes disk seek delays.
    In summary, to edit two simultaneous video streams (i.e. both streams are playing to the screen simultaneously), you need both an efficient hard disk system and an efficient video codec to compensate for insufficient CPU power.
    * be aware that conversion to Cineform intermediate codec will increase file sizes 4-6x.
    ** If you are still pegging your CPU even with the more efficient codec, then you must pre-render for preview.
  20. wow this is getting heavy
    not with the operating system drive and if so, it is prefered a seperate drive and a codec
    why is it like that on premiere?????????? seriously
    I am used to working with Avid and before that with Vegas. and it was never like that. I realy wanted always to work with premiere, I had no Idea it is so unfriendly
    I guess I will be going back to Avid.... dam
    Not for CS4. Because of h.264 licensing issues some features were disabled. The CS5.5 trial is unlimited
    Editing performance is like that for all NLE's. Vegas is just as bad. The problem is the source format, and your hardware setup
    Avid might feel smoother - but you don't edit AVCHD natively, you transcode to DNxHD. But DNxHD will be smoother on all NLE's , not just Avid. You'll get slightly better performance with cineform
    CS5.5 is better if you have a supported Nvidia CUDA enbled card (mercury playback engine GPU accelerates some transitions & effects), but requires more resources (bloated, more ram required). Your hardware might still not be enough
  22. Member edDV's Avatar
    Mar 2004
    Premiere and Vegas attempt to edit h.264 directly. This requires a high performance CPU. Alternately a digital intermediate codec (e.g. Cineform) can be used to speed things up.
    AVID and Apple Final Cut Pro force the use of a digital intermediate. DNxHD (MJPEG) or Cineform can be used with AVID and AIC, ProRes422 or Cineform with Final Cut Pro.
    Your issues are mostly insufficient hardware or disk system relarted. This is compounded with double video tracks.
