Results 1 to 12 of 12
  1. Hey guys i was wondering if you could help me.
    I have a LG BH10LS30 blu ray burner, Problem is it doesnt seem to recognise blu ray media. When i put video in(either blu ray or dvd they play fine no problem, dvds and cds also burn fine, if i put any blank blu rays in the drive windows says the disk is write protected and none of my burning software seems to see the media either saying wrong type of media , ive tried updating the firmware as this drive was working on vista but now im using win7 microsoft say the drive is compatible, ive also tried diffrent brands of media(verbatim and maxell)but still no joy. any ideas..?
    USA
    john8611, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
    Try to choose a subject that describes your topic.
    Please do not use topic subjects like Help me!!! or Problems.
    Thanks,
    Moderator redwudz
    May 2009
    i have the same problem but i didnt know there was a firmware update
  4. Banned
    Freedonia
    Try using ImgBurn and see if you better results burning.
    This burner is old and it may simply be defective by now.
  5. @redwudz, im sorry
    @jman98, hmm possible but i only bought it new last year
    OK i installed imgburn but im still unable to burn to blu ray, in the bottom left corner in the status box it reads disc not empty, the main left hand page reads
    HL-DT-ST BD-RE BH10LS30 1.00 (SATA)
    Current Profile: None!
    Disc Information:
    Status: Unknown
    State of Last Session: Unknown
    Erasable: Unknown
    Formatted: Unknown
    Sessions: Unknown
    Sectors: 4,278,255,615
    Time: 950723:30:15 (MM:SS:FF)
    after adding a small video file to burn the burn option is still grey, this is the resulting log
    I 01:48:54 ImgBurn Version 2.5.6.0 started!
    I 01:48:55 Microsoft Windows 7 Ultimate x64 Edition (6.1, Build 7600)
    I 01:48:55 Total Physical Memory: 16,737,648 KB - Available: 14,557,788 KB
    I 01:48:55 Initialising SPTI...
    I 01:48:55 Searching for SCSI / ATAPI devices...
    I 01:48:55 -> Drive 1 - Info: HL-DT-ST BD-RE BH10LS30 1.00-A9 (D (SATA)
    I 01:48:55 Found 1 BD-RE!
    I 01:49:13 Operation Started!
    I 01:49:13 Building Image Tree...
    I 01:49:13 Checking Directory Depth...
    I 01:49:13 Calculating Totals...
    I 01:49:13 Preparing Image...
    I 01:49:14 Checking Path Length...
    I 01:49:14 Contents: 1 File, 0 Folders
    I 01:49:14 Content Type: Data
    I 01:49:14 Data Type: MODE1/2048
    I 01:49:14 File System(s): ISO9660, Joliet
    I 01:49:14 Volume Label: [Not Configured]
    I 01:49:14 Size: 35,816,280 bytes
    I 01:49:14 Sectors: 17,489
    I 01:49:14 Image Size: 35,913,728 bytes
    I 01:49:14 Image Sectors: 17,536
    I 01:49:14 Operation Successfully Completed! - Duration: 00:00:00
    mode is set to write and i have tried several blanks
    incidentaly when i double click the drives icon windows asks me how i want to treat this disk giving me two options 1:as a flash drive or 2:with a cd/dvd drive, option 2 is greyed out, and when selecting as a flash drive i get a message saying disc write protected.
    As before if have again tried blank cd/dvds they work fine, its only with blu ray blanks
  6. Banned
    Freedonia
    Your image is massive. It's too big to fit on a single layer BD disc. Also you are using a re-writable BD disc. That's what "BD-RE" means. Maybe your real problem is that you are using only single layer BD discs, re-writable or not, and nothing is being written because it's too big to fit on a single layer disc.
  7. @jman OK i think you misread the log file, the file is a tin 35meg youtube video as a test burn as data, andno the disk is in fact a write once disk i dont know why the log says its bd-re, maybe part of my problem img burnb still shows it as not empty and windows says write protected
  8. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    I have that same drive and mine works fine with Verbatim (any), also cheap BD-R (4x) Kodak and OptoDigital media.
    Only difference is I'm one generation behind on ImgBurn. Also I'm on 32bit Win7.
    This drive has yet to produce a coaster since Black Friday 2010.
    Fry's often sells the BD-R Kodak media for around $1 per 25GB disc
    The Kodak media appears to be manufactured by Philips.
    http://www.kiva.org/about
  9. Member edDV's Avatar
    Mar 2004
    Set mode to "Build".
    Also your firmware appears to be 1.00 where mine was shipped with 1.01.
  10. If you are using BD-RE disks, you must format it first.
    You can't write anything without formatting.
  11. Member edDV's Avatar
    Mar 2004
    This drive says
    Found 1 BD-RE!
    even for BD-R media.
    Just checked the LG support site. Ver 1.01 firmware is still current.
    http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=BH1...roduct-profile
  12. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    That kind of posts is of no use and will not help anyone, also with that none info posted no one will be able to help you with...
    In the end, always "i have the same problem" is wrong.
    *** Now that you have read me, do some other things. ***
