hello friends,
i have search many times but i did not find any information regarding my problem. there are many software for mixing but i did not want to mix them i want to burned them permanently. If anyone have any information please shear it.
Also any one know the editing software of .ts & .m2ts like files please also shear information about them. I uses megui & virtualDub i am searching same software for above file types.
thank you.![]()
Virtualdub with directshow plugin http://forums.virtualdub.org/index.php?act=ST&f=4&t=20473&hl=mts& and the vobsub plugin.
Or with avisynth and vsfilter in megui, see https://forum.videohelp.com/threads/286246-Hard-subbing-with-avisynth?p=1731398&viewful...=1#post1731398 -
dear friend,
you not get my problem, i know how to use avisyth and virtualDub but unfortunately we can not use them for .ts & .m2ts or .mts files.
i want same feature of burning subtitle for these type of files.
If you want something that can output to m2ts directly you could use Ripbot264, open .m2ts/ts, click Properties and under Permanent subpictures choose Build in picture and select your srt/ass/sub. Output as an AVCHD and you will get a .m2ts in the STREAM folder. It uses avisynth, textsub, ffdshow and the x264 encoder.
I can not add .m2ts files into TSMuxer
By yaoyao0204 in forum Blu-ray RippingReplies: 2Last Post: 25th Nov 2011, 20:00 -
Add new subtitle to an existing DVD with warning screens, intros & trailers
By Charmer in forum Authoring (DVD)Replies: 7Last Post: 11th Aug 2011, 17:59 -
change aspect ratio & convert m2ts files & brighten videos
By rockerman in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2011, 07:34 -
Add Subtitle with Arabic charset to m2ts blu-ray (BDMV)
By zetallico in forum SubtitleReplies: 3Last Post: 17th May 2010, 16:12 -
How can I add a subtitle into ts file in DVB subtitle format
By elmc in forum SubtitleReplies: 1Last Post: 20th Jul 2008, 14:37
