Looking for a substitute for ConvertXDVD m that have similar features, but a better menus Template in terms of variety.
Do the Batch Videos convert and built in Menus and Burning , al in one.
I like DVDStyler. Not that the templates are that much better IMO but it's very flexible in allowing you to build a (hiearacy) menu system and if you know XML you can create custom buttons/templates. And as far as templates goes you may create a project consiting only of menus with your prefered design and open that as a starting point for new projects as a sort of template.
http://www.youtube.com/watch?v=LYa6nVulBFU -
Yes. By rigth-clicking in the Title Manager area (timeline) you have the option of adding file 2 as a chapter to file 1. And the files may be of different format as well. It also have a check-box "Play All" for every button action that allows you to play all titles in a titlesetDoes it merge 2 files together?
Yes. Multiple files. And they may be in multiple formats. And the default setting is to adjust the bit-rate to fit a given target (may be changed), ie the more files you add the lower the bitrateDoes it Convert Multiple Video Files?
Yes. Either softtiles embedded in a file or from an external file like a .SRT file or a combination. Some of it is shown hereDoes it offer to Combine subtitles with the Video file?
Similar software like sony veas movie studio?
By skorpinok in forum EditingReplies: 1Last Post: 30th Jul 2011, 16:20 -
Something similar to DVD shrink
By millyvanilly in forum Newbie / General discussionsReplies: 8Last Post: 26th Jan 2009, 07:21 -
Software Similar to HDVSplit for DV Video (Not HDV Video)
By tbird2340 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 28th Nov 2008, 10:29 -
4:3 to Letterbox (or Something Similar)
By christopheramos in forum Authoring (DVD)Replies: 2Last Post: 23rd Aug 2008, 02:57 -
ffmpegX and similar converters
By febras1982 in forum Authoring (DVD)Replies: 0Last Post: 27th Nov 2007, 10:02
