I'm opening video (.m2ts) in VirtualDub (I've placed DShowInputDriver in plugins folder).
Now I try to convert the video, but as soon as there is left only some seconds (frames) to finish the conversation, VirtualDub keeps stopping at the same frame and the 'total time estimated' continues to increase.
So, the video will never be converted.
Everything is OK with the m2ts video file.
What shall I do? What's the problem?
Try "remux" it with tsmuxer, open m2ts and make a new ts/mts.
It could also be a decoder problem. You might have to try ffdshow together with haali media splitter. -
inline with Baldrick's reply...
u can try demuxing m2ts by using any appropriate tools from here, and re-mux in to mkv container using mkvtoolnix before importing into VirtualDub with mkv import plugin and haali media splitter.
General Rule for importing H264 into VirtualDub : mkv, mkv import plugin and haalimedia splitter. -
Problem solved
I demuxed it, then muxed to .ts.
Now everything went OK in VirtualDub.
Thanks to everybody.
M2TS in Virtualdub
By aaxpers in forum Newbie / General discussionsReplies: 3Last Post: 29th Jan 2012, 18:30 -
This Virtualdub crash report mean anything to anyone?
By brassplyer in forum EditingReplies: 4Last Post: 30th Jan 2011, 19:35 -
VirtualDub crash?
By goliso in forum Newbie / General discussionsReplies: 4Last Post: 8th Nov 2008, 17:21 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 00:38 -
VirtualDub crash involving Huffyuv
By Xoanon in forum EditingReplies: 4Last Post: 15th Jun 2007, 17:33
