Greetings to all,
I'd like to burn some .avi files onto DVDs for a friend in Australia, who will play them on a regular DVD player. I'm using Toast, which has an option for burning PAL disks. However, do I need to ensure that the frame rate of the .avi file is also 25 fps (the PAL frame rate), or will Toast convert the original frame rate as needed? (I ask because some of the avi files are 23 fps).
http://www.kiva.org/about -
OK, so just to check, the frame rate of the avi file is not important?
What is your source avi? DV camcorder video?
Just standard 720x480i 29.97 fps NTSC DVD. No need to convert frame rate or resolution for most all PAL DVD players.
Should have mentioned progressive 23.976 fps is not supported on all PAL DVD players unless hard telecined to 29.97 fps.
So are you talking about a standard MPEG2 DVD or Divx/xvid avi? If the latter all bets off. Ask your friend what he can play on his player or convert to standard NTSC DVD MPeg2 format which will play. Audio must be MP2 or AC3.I'd like to burn some .avi files onto DVDs for a friend in AustraliaLast edited by edDV; 30th Jan 2012 at 01:59.
Join .avi files, different video sample rates
By -mm- in forum EditingReplies: 22Last Post: 12th Oct 2014, 06:46 -
Newbie question about frame rates.
By MrTorso in forum Video ConversionReplies: 4Last Post: 13th Jul 2011, 22:49 -
need software to convert video files that have different frame rates
By snafubaby in forum Video ConversionReplies: 2Last Post: 7th Mar 2011, 02:33 -
Simplest way to join AVI files with diffferent Sampling rates.
By dagerousdave in forum Newbie / General discussionsReplies: 6Last Post: 15th Nov 2007, 07:03 -
screenshots for PAL DVDs (VOB files)--need frame info + step feature
By ezu0526 in forum Software PlayingReplies: 0Last Post: 8th Jun 2007, 15:06
