I downloaded Subtitle workshop in order to make subtitles for a movie which I could not find any subtitles for (trying different websites like subscene, etc.).
I can't figure out how to actually make new English subtitles for this movie.
First, I click on "new subtitle", then I click on "Insert subtitle". Then, I assume that I click on movie-open. Then this allows me to import the movie file to subtitle workshop. After this, I click "save as". I then see a box with, I guess, a list of different subtitles to choose from. I choose subrip (srt). This is where I do not know what to do.
Please help.
Results 1 to 11 of 11
You could try find subs in another language, google translate it, check/rewrite it , done.
No, I cannot find the subtitles for this movie in ANY language. Hence, the reason I need to make my own. Do I need to basically let the whole movie play out in the software after adding the subtitles in order to actually get the subtitles for this movie?
You must type the subtitles manually. It wont GET the subtitles....
Type out ALL the words to the movie manually?? That is CRAZY. If I really have to do that then this software is USELESS.
By the way, I did read the Help 1.4.4- adding subtitles. I have gone this far. It is AFTER this, what do I do next (see my post)? This is the part I need help on.
You WONT find any subtitle editor that does voice recognition to text.
Even youtube/google can't do it any good. -
SW4 - new subtitles, load the movie
after that do not click stop, click only into movie area, it will pause/play movie or use ctrl+space bar, to go back and forth
use Insert key on keyboard to add subtitles (window has to be active), to select time for subtitle to start click that left half arrow button (7th from right), to choose time for end of subtitle click on that half right arrow),it always enters time where your slider for the movie is located -
Use Subtitle Edit.... You can use the google translate function to help you with the basic translate,
You then have to manually edit any typos or mistranslates... then save as another subtitllle file
Convert pac subtitle to something that I can open in Subtitle workshop
By Tiger_1982 in forum SubtitleReplies: 11Last Post: 15th Aug 2015, 21:49 -
Subtitle Workshop - not creating subtitle at current time location
By botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 04:09 -
how to open chinese subtitle in subtitle workshop
By pcb in forum SubtitleReplies: 2Last Post: 28th Nov 2010, 17:03 -
Subtitle Workshop 4 crashes when loading subtitle file
By Batou in forum SubtitleReplies: 0Last Post: 26th Mar 2009, 07:57 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 23:16
