Results 1 to 9 of 9
    Jan 2012
    america
    I've been searching and can't seem to find the solution for my specific issue... Well I have a series of episodes and i want to convert from mkv to mp4. At the beginning everything was cool, I converted over 30 episodes.. Then it couldn't convert the 20 last episodes!
    The problem is that i get this erros message : Error during aac conversion.
    Also in the audio box (where normally in the convertable episodes it says ''undefined'') is completely blank!
    i went in VLC player to check my audio and it says its aac ! any ideas ?
    Thank you ..
    Try mkvtomp4 and rebox.net.
    Jan 2012
    america
    are they as fast as gotsent ? coz i dont want to convert like i was doing it with handbrake ( 1 hour for an episode)
    Jan 2012
    america
    i tried mkvtomp4 and it was faster than gotsent bt the audio was out of sync ... can i do something about it ? using the options or something..
    Jan 2012
    america
    anyone help please ?
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Please wait some DAYS before you bump/reply. Not 30 minutes.
    Post more info from your mkv, use mediainfo, view->text.
    Jan 2012
    america
    General
    Unique ID : 254167325277565814479771874100696090425 (0xBF36D8A4BCAD8674B313EEDC612C8739)
    Complete name : C:\Users\Windows 7 Pro\Desktop\Marineford\[yibis] One Piece 458 [720p][7CB7D473].mkv
    Format : Matroska
    Format version : Version 2
    File size : 322 MiB
    Duration : 23mn 34s
    Overall bit rate : 1 911 Kbps
    Encoded date : UTC 2010-07-17 18:04:42
    Writing application : mkvmerge v4.1.1 ('Bouncin' Back') built on Jul 3 2010 22:54:08
    Writing library : libebml v1.0.0 + libmatroska v1.0.0
    Attachment : Yes / Yes
    Video
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 9 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 23mn 34s
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable / Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Writing library : x264 core 104 r1677 19df41a
    Encoding settings : cabac=1 / ref=9 / deblock=1:0:0 / analyse=0x3:0x13 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=9 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=120 / rc=crf / mbtree=1 / crf=20.5 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:0.70
    Language : English
    Default : Yes
    Forced : No
    Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 23mn 34s
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Default : Yes
    Forced : No
    Now what do I do?
    Jan 2012
    america
    Is there a fast converter that can work or something to make the sound match the image?
    i tried to use YAMB too but the audio was out of sync with this tool too
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    It's probably because the frame rate is variable. No, I don't know any good methods then.
