  1. I hope this is the right place to post this question...
    I have a bunch of DVD-R's from transfers I've done (VHS to DVD). Each dvd has 2 one-hour programs.
    I'm wondering if it's possible to take these and dump them onto a DVD-R Dual Layer disc, or perhaps a Blu-Ray disc, or a back-up external hard-drive. I'm concerned with quality loss and am wondering what my options are. I want another back-up option in case something goes wrong with the discs, but with another option that's perhaps space saving?
    If anyone can give insight as to any or all of these options are possible. Also what software would I use to do it?
    Thanks in advance for feedback.
    Oct 2005
    666th portal
    you can extract the mpeg-2 from the vob wrapper and save them to a hard drive. try vob2mpg.
  3. When I extract the mpeg-2 and save each episode to my hard drive. There won't be any quality loss right?
    So if I re-burn a new dvd with episodes on it, it will still maintain the quality from my original dvd, correct?
    I'm sure this is correct, but just want to verify that quality loss won't be lost between ripping, re-burning, etc.
  4. Banned
    Freedonia
    That is correct.
    Depends on what you use. There shouldn't be any quality loss but some authoring programs are rather infamous for re-encoding anything they are given. As long as what you use to create a DVD or BluRay doesn't re-encode then there will be no quality loss.
    Feb 2012
    Lyon France
    You can make .ISO files from your DVD with ImgBurn or some other software, so you will lose really nothing.
    Video DVD ISO files can be played with VLC just the same way as your DVD.
    You can if you need burn them back to DVD also with ImgBurn.
    GB are cheaper on HDD than on DVD and take less space on a shelf.
    One can do lossless conversion between DVD and .MPG file but this is not as easy as using .ISO
    I would not advise you to re-encode your videos to a more recent format (mp4 or else) to gain space unless you can make a powerful video restoration. re-encoding low quality videos such as VHS transfers is usually rather lossy.
