recently downloaded an Australian feed sporting event which is 720p HD but PAL 25fps. I want to convert to NTSC 59.94fps if at all possible. I did use multiavchd but that made it 23.97fps and the result was a very slow looking blur on my HDTV.
so, can Handbrake provide the solution? It has so many options, I don't know which is correct. Which one(s) to use in Deinterlace, Detelecine, Decomb, Denoise (all in Video Filters)
found these guides on VideoHelp, but they appear to be only for SD. Anything for 720p
https://www.videohelp.com/guides/category/guides/category/how-to-convert-pal-to-ntsc-or...ions-4;41#4;41
or perhaps there is some other app besides Handbrake for this issue?
thanks very much for any help
the Sony BR player can play it on my Samsung Plasma, however, the video quality is terrible as everything appears in slow motion and blurred. 59.94fps is what I need , but is there a way to get there?
Is it a 120 Hz or 240 Hz TV? Try turning off the motion smoothing option.
Handbrake has frame rate conversion but doesn't include 59.94 fps. Is your source really progressive? What container? Xvid4PSP has a similar GUI and frame rate conversion tools in the Video -> Interlace/Frame Rate section. Its options include repeating frames, blending frames, and motion interpolating frames.Last edited by jagabo; 29th Jan 2012 at 07:50.
TV is Samsung Plasma 60hz, but advertised at 600hz which is gimmick as far as I know, but that's a different issue.
Even on my Toshiba LCD, I do get the slow motion look with the same Sony BR player. I've tried all settings on the Samsung but no luck.
The source file is this per Mediainfo . How to see if that is PAL or NTSC? also, looks to be "progressive"
General Complete name :
Format : Matroska File size : 1.73 GiB Duration : 59mn 59s Overall bit rate : 4 126 Kbps Writing application : Lavf52.39.0 Writing library : Lavf52.39.0
Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Muxing mode : Container profile=Unknown@3.1 Codec ID : V_MPEG4/ISO/AVC Duration : 59mn 59s Bit rate : 3 916 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.170 Stream size : 1.64 GiB (95%)
Audio ID : 2 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Format_Settings_ModeExtension : MS Stereo Codec ID : A_MPEG/L3 Codec ID/Hint : MP3 Duration : 59mn 59s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Stream size : 54.9 MiB (3%) Writing library : LAME3.98.2 -
"PAL" and "NTSC" terms don't really apply to HD
When you mean "slow motion" do you mean choppy? or something else? Because slow motion isn't the same thing
For example, How does it look on your computer ? (Played with software)
You can try to interpolate new "inbetween" frames, eg. with avisynth. But keep in mind you're starting with 25 actual frames per second, and your're trying to more than double that. There are often undesireable side effects like edge morphing. If you put porsche body kit on a Honda civic, it's still a Honda civic
HDTV 720p 50 fps -> SDTV PAL 576i/p 25fps
By joosty in forum Video ConversionReplies: 22Last Post: 7th Nov 2010, 22:33 -
Handbrake and 720p video
By jcj487 in forum Video ConversionReplies: 5Last Post: 18th Aug 2010, 13:34 -
converting PAL (25fps) to NTSC(23.97fps) with audio
By drew24 in forum MacReplies: 6Last Post: 21st Dec 2009, 09:45 -
29.976 to 25fps (removing pulldown from a NTSC converted PAL film transfer)
By ecc in forum Video ConversionReplies: 25Last Post: 15th Jul 2007, 22:31 -
HDV ---> 720p @ 59.94fps
By racer-x in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 3rd Jul 2007, 11:37
