Results 1 to 12 of 12
  1. I have a mkv file.Following is the info
    General
    Format : Matroska
    Format version : Version 2
    File size : 104 MiB
    Duration : 20mn 43s
    Overall bit rate : 701 Kbps
    Writing application : HandBrake 0.9.5
    Writing library : libmkv 0.6.4.1
    Video
    Format : AVC
    Format profile : Main@L3.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 20mn 43s
    Nominal bit rate : 630 Kbps
    Width : 848 pixels
    Height : 480 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.065
    Writing library : x264 core 112
    Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=9 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=2 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=0 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=630 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : No
    Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 20mn 43s
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Default : Yes
    Forced : No
    I have a subtitle for that video file.The problem here is that there is some error in the subtitle(the text comes long after the video).Alright,had it been a constant error i could have fixed it with vlc,but the error keeps changing.(keeps on icreasing every sec).How do i fix it????
    You must probably resync it completly with for example subtitle edit. Or try find another subtitle file that matches your source video better.
  3. Frame rate mode : Variable
    Does it go in/out of sync? - VFR is another problem - you would have to know CFR and VFR timestamps.
    Probably easier to get original source then encode it CFR. Then your subs will probably match
  4. i searched the net.No other subtitles.Maybe the subtitles are bad.But i think the mkv file is compressed to a very great extent because of which they are going out of sync.Is that possible?Temme a way to decompress the mkv file so that i can check if the subtitles sync with the decompressed video.
  5. Baldrick resynching the subtitle is as good as making one by myself.It takes hell lotta time.
  6. poisondeathray how do i change the VFR to CFR?
  7. Originally Posted by poisondeathray View Post
    poisondeathray,how do i change the VFR to CFR??
  8. There might be another reason for the sub sync issue, I'm just guessing VFR might play a role
    You take the original source (not the mkv) , and encode it CFR
    Sometimes you can convert the mkv to CFR using avisynth with DirectShowSource, convertfps=true, but it doesn't always work. It's better to start with original source
    See these:
    http://forums.animesuki.com/showthread.php?t=34738
    http://avisynth.org/mediawiki/VFR
    http://docs.aegisub.org/manual/Video
    No. It has nothing to do with it. If you decompressed it, it would be 10-20x larger and subs would still out of sync
  9. But i don't have the original source.Its a downloaded file.Any chance of fixing this one?(given the fact that you said "it doesn't always work").
  10. One more thing.We are only thinking about the video file.Can there be a possibility that the subtitles itself are bad.(Though i hardly think so).
  11. Yes, it might be the subs are bad. Go ask wherever you downloaded it from
    If you want to try converting it to CFR (might just be a waste of time, and re-encoding)
    DirectShowSource("video.mkv", fps=23.976, convertfps=true)
    AssumeFPS(24000,1001)
    Feed that script into something like megui, or ripbot, or xvid4psp
  12. Alright,I'll try that!!Thanks!
