I have a video I need to trim. I'm working on a W7 64 bit PC. Whats the best/easiest free program?
Below if the Media Info:
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 53mn 55s
Bit rate : 1 036 Kbps
Width : 624 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.157
Stream size : 400 MiB (72%)
Writing library : XviD 1.1.2 (UTC 2006-11-01)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 53mn 55s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 148 MiB (27%)
Alignment : Split accross interleaves
Interleave, duration : 33 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Solveigmm avi trimmer is easy and free. If it fails use avidemux(click on it for guides).
in line wirh baldrick's reply, VirtualDub, VirtualDubMod (which requires few VFW codes installed) and AVIDemux will cut and trim AVI in direct stream copy mode.
VCD Cutter
By devilcoelhodog in forum EditingReplies: 0Last Post: 16th Jan 2010, 15:39 -
h.264 ts cutter
By stewart041170 in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jan 2010, 15:06 -
Looking for Mpeg2 Cutter
By 557953 in forum EditingReplies: 6Last Post: 8th Sep 2008, 22:56 -
Is there an AVI cutter that does in-place cutting?
By cheerful in forum Newbie / General discussionsReplies: 2Last Post: 30th Aug 2008, 23:16 -
What is a good xvid, avi cutter (for unwanted commercials) w/batch process?
By kbal in forum Video ConversionReplies: 5Last Post: 20th Dec 2007, 10:34
