I have a few MPG files that I recorded from TV.
Is there a FREE way to remove the ADS?
Cheers.
Results 1 to 9 of 9
Comskip combined with Mpeg2Schnitt or Cuttermaran can work with SD files to automate commercial removal, but I don't personally find it to be accurate enough. PDRs recommendations are good mpg editors that can be used to trim out commercials manually, but be prepared for A/V sync issues. If there are any errors (even one bad/missing audio packet or video frame) in the files audio will loose sync.
As you have already been advised in a few previous similar threads, if you want something that can remove commercials manually and compensate for minor errors in the stream to avoid sync issues, payware (VideoReDo Plus) is still required. -
You don't give any particulars about how or with what you're capturing, etc.
HDTV2MPEG2 is often overlooked. It's very simple, and can scan for adverts. I've found the automatic commercial removal to be quite accurate. You can preview and double check the mark in/ mark out points before saving a clean file.
Before I got my HD-PVR, I used a Leadtek card that saved high-definition or standard definition broadcasts to mpeg2 transport streams and used HDTV2MPEG2 a lot.
Good luck.Pull! Bang! Darn! -
Hmmm, that sounds very much like a couple of comments on the tool by a few people who couldn't get it to work for them. There were some versions with a bug causing that error message for valid transport streams. Did you install the newest (last) version? BTW, the tool is no longer being actively developed.
Been a while since I used it, and that was on XP. It would help if you filled in your computer details. It may be that it needs to be run in compatibility mode on Vista or Win7. But that's just a guess.Pull! Bang! Darn!
Method to remove ads/trailers from BD rip?
By micro9mm in forum Blu-ray RippingReplies: 2Last Post: 28th Dec 2010, 19:28 -
How can I remove ads from my video cd movie
By nusratjaveid in forum EditingReplies: 21Last Post: 10th Jun 2010, 16:14 -
how to remove the textual ads from mpeg
By sumeshkri in forum EditingReplies: 13Last Post: 9th Nov 2008, 21:46 -
How do I remove/block Flash ads?
By videohalp in forum ComputerReplies: 4Last Post: 26th Sep 2008, 19:45 -
By sumeshkri in forum EditingReplies: 2Last Post: 22nd Dec 2007, 04:29
It got so bad that by the last 15 minutes of movie there is NO sound at all.
