  1. This is my error
    CD image cd1.bin is invalid
    Need mpeg 2 which was encoded for super video cd.
    Audio 44.1 khz mpeg- 1/2 layer 2 stereo/duel channel /muti-channel
    Video 480x480 at 29.97hz
    or 480x576 at 25hz
    The following problems were found stream encoding which is invalid
    for a supervideo-cd
    no video-cd
    no audio
    any ideas if i can solve this problem
    Thanks Daza
  2. Hi Dale I hope you already read my last mail about this topic
    another person on the forum responded correctly that if you only burn the (muxed) mpeg file you loose some options that's correct but still it works as being a svcd
    so better stick to the cue sheets and you can leave the mpeg files on your drive
    but if you have enough space left to view them with windvd or other player, that's why you check 'don't delete any temp files'
    but if you dont have much space uncheck it
    You can watch the svcd from cd-rom of course but my pc gives many 'hicks' when i try that
    I bought the extra 60 Gig (I told you during our 'live' conversation) just for storage of the VOB files!!!!
    cu,
    Bart.
