CAN YOU HELP I HAVE A PANASONIC RV31EB,THE PROBLEM BEING EVEN WHEN I HAVE MACROVISION REMOVER CONNECTED BETWEEN MY DVD PLAYER AND VIDEO RECORDER,THERE SEEMS TO BE ANOTHER TYPE OF PROTECT BEING SENT FROM THE DVD PLAYER,ANYBODY KNOW OF A WAY AROUND THIS.THIS ONLY HAPPENS WHEN I TRY TO TRANSFER VCD'S DVDS ARE OK
<font size=-1>[ This Message was edited by: daz l on 2001-07-26 13:12:48 ]</font>
I didn't thinkg the VCD format even included Macrovision or any other form of copyright protection.
I have only needed to transfer a VCD to a VHS tape once and I had no problem but it is unfair of me to say that since I have my DVD Player connected through a SIMA Color Corrector box.
Still, I don't think this should be a problem.
You say you have no problem copying a DVD to VHS... what exactly is the problem you are experiencing while transferring a VCD?
Oh yeah, by the way... turn off your "Caps Lock" your shouting.
<font size=-1>[ This Message was edited by: BadAsh on 2001-07-26 13:49:47 ]</font> -
the problem i have is the picture is rolling and the video recorder cannot tune into the picture.i have hear it is the way the vcd is encoded
I'm glad I actually read this topic, it just look way too stupid and couldn't think of an idiot to ask it. But you not stupid, just missing some info. VCD aren't protected so the macrovision connecter is useless with vcds. The problem is that your VCD is in PAL video format. So there is 2 things you can do:
1. switch the video out of the dvd player to NTSC (dpends if you dvdplayer is capable of doing that)
or
2. Re-encode to vcd into NTSC video format. (You can use the encoder on the tools page to do so)
That's all you have to do is one of these things and you should have no problem.
What editing software to use after transferring VHS to DVD?
By garyg45 in forum Newbie / General discussionsReplies: 8Last Post: 3rd Mar 2012, 10:20 -
Transferring multiple VHS tapes at once...
By robin_west in forum Capturing and VCRReplies: 10Last Post: 29th Dec 2011, 05:16 -
transferring vhs videos from vcr to computer
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 24th Feb 2009, 23:17 -
Transferring VHS to DVD
By Scotty427 in forum RestorationReplies: 50Last Post: 16th Aug 2008, 00:52 -
Good device for transferring VHS to DVD on PC
By ericlhamilton in forum Capturing and VCRReplies: 1Last Post: 17th Mar 2008, 14:42
