i'm trying to load a video captured from my hauppauge PVR @ 1280x720 with the .mp4 file extention and when I load it in Vegas half of my video is cut off. When I look at my video properties while the file is selected in the open file window it's showing 720x480 or something similar to that even though the file is actually 1280x720? Does anyone know what the problem may be? I'm trying to explain the best I can considering that i'm new to this.
Can you post the mp4 details? Use mediainfo, view->text.
You could also try "remux" the mp4 to avi with mp4camtoavi or to a ts/mts file with rebox.net. Then open the avi or ts/mts in vegas. -
General
Complete name : C:\Users\Robert\Desktop\2012_1_25_19_6_24.MP4
Format : MPEG-4
Format profile : 3GPP Media Release 4
Codec ID : 3gp4
File size : 55.9 MiB
Duration : 1mn 22s
Overall bit rate : 5 695 Kbps
Encoded date : UTC 2012-01-26 01:07:53
Tagged date : UTC 2012-01-26 01:07:53
Video
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Duration : 1mn 22s
Bit rate mode : Variable
Bit rate : 5 572 Kbps
Maximum bit rate : 20.0 Mbps
Width : 720 pixels
Original width : 1 280 pixels
Height : 480 pixels
Original height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 59.940 fps
Minimum frame rate : 59.887 fps
Maximum frame rate : 60.006 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.269
Stream size : 54.7 MiB (98%)
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1mn 21s
Bit rate mode : Constant
Bit rate : 107 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 1.04 MiB (2%)
Language : English
Tagged date : UTC 2012-01-26 01:07:53 -
I fixed it! I just installed older Drivers 1.5.7.0 and it worked like a charm!
Sony Vegas Movie Studio 9 Platinum: Event pan/crop keyframing problem
By Dude E. O'Loo in forum EditingReplies: 2Last Post: 22nd Jan 2012, 20:09 -
Video Artefact Problem - Sony vegas Movie Studio Platinum 9
By abeelandig in forum Video ConversionReplies: 5Last Post: 11th Jun 2011, 11:40 -
Vegas Movie Studio HD Platinum 10
By jjblackisback in forum SubtitleReplies: 3Last Post: 26th Apr 2011, 21:28 -
What is the difference between Vegas Pro and Vegas movie studio platinum
By jbitakis in forum Newbie / General discussionsReplies: 4Last Post: 18th Feb 2009, 01:41 -
What do you think of Vegas 8 Platinum?
By Jensen in forum EditingReplies: 6Last Post: 14th Jan 2008, 11:02
