  1. Hi
    I've created a blu ray video that was encoded with RIPBOT and is now sat in a BDMV folder, is it possible to add a menu
    to it now in that state or do you after add the menu before encoding the video ?
    Im currently playing around with MultiAVCHD but it seems like i after re-encode the video again if i want to add a menu which i would prefere to avoid since it took 28hours to encode
    Multiavchd shouldn't reconvert. Did you try output?
  3. Sorry i dont understand what you mean. I've just found you can import a BDMV folder which prompts MultiAVCHD to go in to blu ray re-auther mode however the menu settings are greyed out and you can't select any options.
    Your right that you dont after re-encode again.. the blu ray re-auther mode just muxes the video how ever i now need to find away to add menu's
