Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 31 to 60 of 61
  1. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    anyone have an apple HDVA sample uploaded or available somewhere? the op may be having problems posting from s.a.
    Jan 2006
    Northern Pacific SW
    I have a largish collection of .mov entrapped HDV, from many different sources.
    I don't want to drop each file individually into mediainfo.
    How can I narrow it down to likely HDVA? Is it likely to be footage from a particular camera or a project rendered in FCP or ???
  3. Originally Posted by dLee View Post
    mediainfo can open a folder and export a text file listing mediainfo contents of the videos in the folder (file=> open => folder) , file=> export
    Then you might open that exported text file in a text editor , word, or even wordpad/notepad and search for the string "HDVA"
    This will quickly determine if you have HDVA in that folder , and the name of the file
    Oct 2005
    666th portal
    fcp .mov format i think. if you highlight more than one, right click - mediainfo - it will pop up a box for each one.
  5. And you should liberate those videos stuck in prison be a freedom fighter
    FCP doesn't always export HDVA, I have some that were HDV1 and 3 from a MAC.
    I think HDVA is from some JVC HDV cameras
    Oct 2005
    666th portal
    jvc would also explain the op having a HDVA 720 mov.
    Jan 2006
    Northern Pacific SW
    OK, thanks for the tips.
    I have something I must do this afternoon (2:45pm PST here). I'll start looking this evening.
    Potential issue: I'm on a Win7PC and I only have Vegas Pro 10, so if I have an HDVA .mov file, I won't be able to cut it down for posting. I've got an iMAC in the house, but I've never tried iMovie with HDV footage - never use it for work - I don't remember if I can even play HDV on it.
    My files are already liberated. They've been re-wrapped, edited, rendered in Vegas and shown at the Festival I work for. These are just the files I got from MAC hypnotized filmmakers. I have to fight this every year.
    I've got some JVC HDV files, but I capped them, so that won't work.
    Do we need a couple of seconds or a couple of minutes?
  8. A few seconds is enough
    I fairly certain you need FCP for HDV/MOV (all types), I don't think imovie will open it
    You can try the make sample utility aedipuss linked to earlier (I'm not sure what it does to the header or metadata)
    But the fact that any video converter identified the OP's video as HDVA, and was able to convert it , makes me think that FFmpeg / FFmbc should be able to do it too , or rewrap it (or perhaps mencoder)
    HDV is just MPEG2, so even demuxing it with DGIndex to m2v makes it infinitely more usable on a PC. MOV is like green kryptonite for PC's
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    makesample leaves HDV header identifiable. 20mb is about a 5 sec. clip and about as small as you want to go. here's mediainfo from a makesample cut file.
    General
    Complete name : G:\canon_hv30\tape1-2011_12_18-13_40_15-SAMPLE.m2t
    Format : MPEG-TS
    Commercial name : HDV 1080i
    File size : 20.0 MiB
    Duration : 6s 90ms
    Start time : UTC 2011-12-18 13:40:15
    End time : UTC 2011-12-18 13:40:21
    Overall bit rate : 27.0 Mbps
    Maximum Overall bit rate : 33.0 Mbps
    Encoded date : UTC 2011-12-18 13:40:15
    Video
    Menu ID : 100 (0x64)
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@High 1440
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=15
    Codec ID : 2
    Duration : 6s 6ms
    Bit rate : 25.3 Mbps
    Maximum bit rate : 25.0 Mbps
    Width : 1 440 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.542
    Stream size : 18.1 MiB (90%)
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Codec ID : 3
    Duration : 6s 120ms
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Delay relative to video : -56ms
    Stream size : 287 KiB (1%)
    Jan 2006
    Northern Pacific SW
    Looks like I don't have any hdva. Most of the footage is hdv6 and the FCP renders are mostly AVC.
  11. Good day again everyone.
    A very big thank you to you all for all the assistance.
    Just to confirm what Any Video Converter is saying on my files.
    Both are showing as HDVA format, 1280x720, with one 25fps and the other 50fps
    Converting them, I was using the ffmpeg command line suggested by poisentdeathray, however those files were still not usable in Vegas (10 Pro 64bit on Vista Ultimate 64). However, taking those files and running them through Any Video Converter, saving to .mpg files (settings: original resolution, 25fps) let me at least access the video stream (no audio). This did however look like old cellphone footage once it reached Vegas.
    I will try get a larger sample of the file (20MB) uploaded, however this does take time with the slow Internet here.
    A very big thank you again to all
  12. Okay. finally have a larger example file uploaded.
    Same location: http://www.samdb.co.za/videos/disputedfaith_0.mov
    Thank you, once again!!
  13. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    is the 20mb sample of the original HDV? it's mpeg-4 not hdv mpeg-2.
  14. Hi Aedipuss
    Yes, it's of the original. My second post gives details obtained from mediainfo for the original file.
    Could any change have occured using DGSplit? Or could this indicate some sort of file corruption?
  15. Try it with makesample instead of dgsplit - dgsplit doesn't perserve the header info.
    If you're in a time crunch , you can get any video converter to use different compression instead of MPEG2. Use lossless like huffyuv/AVI (filesizes will be ~10x). Or if you can try to specify "copy" for the video stream
  16. Thank you all, once again.
    Going to try makesample, and will try other settings for Any Video Converter (although, several other formats I tried there failed to do anything, and I got an error from the program).
    Thank you all
  17. The sample I downloaded was 20MB, not 555Kb as in aedipuss' link
    I used DGIndex to demux elementary video, and ffmpeg to re-wrap in mpg-ps (mpeg progam stream .mpg) , to import into vegas
  18. Originally Posted by dLee View Post
    I know I wrote "convert", but I don't think it's converting - probably just re-wrapping. Long (not broken up into clips), footage-type HDV files are done in minutes.
    I'm having trouble finding something that explains the difference between HDV1,2,3,A. Do you have a good link?
    Difference between HDV flavors is explained here: (table at bottom of page)
    http://aeroquartet.com/movierepair/hdv
    Regards,
    BJ
  19. Will try same, poisendeathray
    Just running a little low on brain power at the moment due to too long in front of the screens, and lack of sleep
    Thank you all, once again. Will post my results!!
  20. Originally Posted by AeroQ View Post
    Thanks!
  21. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    the file i posted was re-encoded to show a playable version.
  22. Good day everyone
    Again, a big thank you for all the help, time and advice.
    Am busy trying poisendeathray's instructions. However, playing the file only gets me a certain distance, and then stops (whether demuxing, or playing). Just trying to locate the log file to take a look there (will post what it says)
    But looking in the status / info field, there are many errors that flash past, until the program just stops on 'mb addr inc error'
    Thank you all once again
    [edit]
    Adding the log below. Unfortunatly it does not list the errors completely.
    Stream Type: Elementary
    Profile: main@high
    Frame Size: 1280x720
    Display Size: [not specified]
    Aspect Ratio: 16:9 [3]
    Frame Rate: 50.000000 fps
    Video Type: PAL
    Frame Type: Progressive
    Coding Type: B
    Colorimetry: BT.709*
    Frame Structure: Frame
    Field Order: Bottom
    Coded Number: 2182
    Playback Number: 2182
    Frame Repeats: 0
    Field Repeats: 0
    VOB ID:
    Cell ID:
    Bitrate: 21.081 Mbps
    Bitrate (Avg): 19.690 Mbps
    Bitrate (Max): 25.887 Mbps
    Timestamp:
    Elapsed: 0:00:43
    Remain: 0:09:04
    FPS: 49.92
    Info: mb addr inc error
  23. Not sure, maybe the file is corrupted or has errors ?
    But any video converter was able to convert it successfully ?
    At this point , I wouldn't waste any more time , and just use a lossless (or near lossless) intermediate with any video converter
  24. Again, thank you all for all the help. Most appreciated.
    The 'sort of' success I've had was to use ffmpeg (as per poisendeathrays suggestion and command line). Then running the resultant file through Any Video Converter got a file (without audio) that I could use, but at what seemed like a lower quality (meant to be HD, but I can not view the original to compare)
    I have now just tried vReveal to convert to an SD AVI (process took a while, so will test the output shortly)
    Agree though. This has taken way too long. For that I thank every one. Have learnt a ton too, which I hope I can impart to others
    Will post any results I find back here!!
  25. weren't you able to convert the file directly with any video converter ? You said you made a low quality mpg ?
    Instead of using mpg, use uncompressed AVI, or lossless compression like huffyuv. Even mpg is ok if you use high enough bitrate
    I guess another question is did ffmpeg convert the file successfully (i.e copy the video stream) ? but only you couldn't open it in vegas? was the file approximately the same size as the input video (minus audio, but add transport stream overhead) ?
  26. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    were you able to cut a sample of the original HDV with the program i uploaded? what you pasted of the log looks like it should be HDVA - 720 50p.
  27. Good morning everyone, and again many thanks
    So vReveal ran for a long time, and spat out a 15GB AVI file. Audio was a little over twice the length of the video when importing into Vegas. I was only using the free version of vReveal, so the video is 480p.
    @poisendeathray:
    I wasn't able to convert the file directly in Any Video Converter, but used your suggested ffmpeg method. From there I was able to run that file through Any Video Converter to output an MPEG file (minus audio). This was then rather compressed, as it was MPEG-2. Picking another format gave an error in the program.
    @BigMeanie
    My second post with the .mov URL http://www.samdb.co.za/videos/disputedfaith_0.mov is the sample at 20MB.
    However, DGIndex stops about 20 / 30 secs in, with a 'mb addr inc error' message.
    Are those messages indicative of a corrupt file perhaps?
    MediaInfo stats current framerate 25fps / original 50fps
    General
    Complete name : G:\Faith.mov
    Format : MPEG-4
    Commercial name : HDV 720p
    Format profile : QuickTime
    Codec ID : qt
    File size : 1.35 GiB
    Duration : 18mn 3s
    Overall bit rate : 10.7 Mbps
    Encoded date : UTC 2011-10-30 13:17:15
    Tagged date : UTC 2011-10-30 14:36:39
    Writing library : Apple QuickTime
    Media/UUID : ACDD23B6-95CA-49C1-954A-D63347DA461A
    Video
    Format : MPEG Video
    Format settings, GOP : M=3, N=12
    Codec ID : hdva
    Duration : 18mn 3s
    Bit rate : 9 148 Kbps
    Maximum bit rate : 18.3 Mbps
    Width : 1 248 pixels
    Original width : 1 280 pixels
    Height : 702 pixels
    Original height : 720 pixels
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Original frame rate : 50.000 fps
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.418
    Stream size : 1.15 GiB (86%)
    Language : English
    Color primaries : BT.709-2, SMPTE 274M, SMPTE 296M
    Transfer characteristics : BT.709-2, SMPTE 170M, SMPTE 274M, SMPTE 293M, SMPTE 296M
    Matrix coefficients : BT.709-2, SMPTE 274M, SMPTE 296M
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : sowt
    Duration : 18mn 3s
    Bit rate : 1 536 Kbps
    Bit depth : 16 bits
    Stream size : 198 MiB (14%)
    Language : English
    Menu
    Language : English
    Encoded date : UTC 2011-10-30 14:36:39
  28. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    looks like the cut sample is corrupt. but even so the drag drop convert will remove the video and create a vlc playable file. vegas won't accept it but premiere pro does and identifies it correctly as 720 50p. it's possible if you used the complete file it would create a vegas readable version.
  29. Member
    Nov 2009
    Using this mencoder command line I was able to re-wrap the 20MB mov sample to a usable HDV .m2t file.
    mencoder.exe disputedfaith_0.mov -ovc copy -oac copy -ffourcc MPG2 -o disputedfaith_0.m2t
    Also, if you have ffdshow installed with Mpeg2 in avi enabled you can use this command:
    mencoder.exe disputedfaith_0.mov -ovc copy -oac copy -ffourcc MPG2 -o disputedfaith_o.avi
    This avi file opened and displayed correctly in Virtualdub so should open in Vegas.
  30. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    mplayer creates a file vegas won't accept also.
