I'm using RipoBpot264 v1.17.0 to compress MKV video files but the audio voices are allways out of sync.
Using Avisynth, HaaliMediaSplitter and Ffdshow.
I click "2-Pass" and reduce the size for abt 50% of original.
Can anyone help?
Ty
Skrapy
Was the source VFR (variable frame rate ) ?
What kind of sync issue? constant sync (e.g. 1 sec all the way through) , or progressively worsening ? -
Thank you for your reply.
How can I know whether the source is VFR ?
This is what I used:
Video settings : Profile : [High 4.0] HD progressive FPS: 25 Frames: 151984 Duration:1:41:19,36 Mode: 2-Pass KBPS 1.024
Audio Settings: Profile: x.x Copy Stream Frequency: 44100 Chanels: 2 Duration: 1:41:18,148 Normalize: Off
The original size is 3,8 GB, Locked size and changed to 1,6 GB
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
