Results 1 to 11 of 11
  1. looking for a gui tool that will let me batch convert mp3 with a jpg (for a still background "video" the whole time) to a video format.. any tips?
  2. anyone?
    does this belong in a different forum?
    Feb 2004
    Australia
    Welcome disgust.
    Any number of app's can do it ... picasa, WMM, wax2 ... just a matter of knowing which buttons to click for required output.
    And then again ... what is your current operating system ?
    If you like command line tools you can use ffmpeg, something like
    ffmpeg -i image.jpg -i audio.mp3 -f image2 -loop_input -vcodec x264 -acodec copy -shortest newvideo.mp4
    See https://sites.google.com/site/linuxencoding/ffmpeg-tips
  5. i'm on windows 7. my requirements are just that it be able to be done in batch, preferably with a gui. can SUPER do this?
  6. Member Cornucopia's Avatar
    No, Super doesn't do that.
    What's so difficult with that command line? It's not like Win7 can't do that.
    Mar 2011
    Paris, France
    What does "-f image2" do?
    Running "ffmpeg.exe -h" shows this:
    -f fmt force format
    -loop_input deprecated, use -loop
    Also, I get this error using "-vcodec x264":
    Unknown encoder 'x264'
    Next, I tried "-vcodec libx264", to no avail:
    [mp3 @ 02109020] max_analyze_duration 5000000 reached at 5015510
    [libx264 @ 02665020] width not divisible by 2 (465x315)
    Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
    Which video codec is recommended to upload a file to YouTube?
    Thank you.
  8. Member bat999's Avatar
    Feb 2008
    Hi
    The syntax has changed.
    Use this instead:-
    ffmpeg -loop 1 -i image.jpg -i audio.mp3 -shortest -c:v libx264 -c:a copy newvideo.mp4
    Mar 2011
    Paris, France
    Thanks for the tip. For some reason, I get the following errors:
    [image2 @ 02102320] max_analyze_duration 5000000 reached at 5000000
    [mp3 @ 02A16B00] max_analyze_duration 5000000 reached at 5015510
    [libx264 @ 028F2560] width not divisible by 2 (465x315)
    I also tried this, which seems to work but turns a 40MB MP3 file into a 262MB AVI file
    ffmpeg -f image2 -loop_input -i picture.jpg -i audio.mp3 -vcodec mpeg1video -qscale 2 -acodec copy -shortest output.avi
    Truncating packet of size 1024 to 546
    Truncating packet of size 1024 to 1
    FWIW, I'm using ffmpeg.exe version 0.10.1.
  10. Member bat999's Avatar
    Feb 2008
    Mar 2011
    Paris, France
    Sorry about that. I didn't expect ffmpeg to fail simply because of the picture.
    After resizing it so that width/height are divisible by 2, the command ran successfully to generate the MP4 file (50 MB).
    Thank you.
