  1. Hello,
    When i want to make an ISO file in the program "Corel DVD MovieFactory Pro 7 (version 7.00.398.0)", during the process it fails because of this:
    "Function calling sequence is not correct."
    Could you please tell me, what does it mean? I didnt have such problems before.
    I tried to change almost all settings, but still i cant create an iso file, it fails. I tried to create a dvd folder, but also unsucceeded.
    Thank you for your answers!
    Image Attached Images
  2. Member DB83's Avatar
    Jul 2007
    Have you tried with a smaller directory tree ?
    That is probably not the answer but 6 or 7 levels is quite a lot.
  3. Thank You for this notification. I'll try, maybe it'll work
  4. Member Cornucopia's Avatar
    Yeah, try something like "D:\Temp\" or "D:\DiscImages\"
    Or try putting a disc in the burner (even though you don't intend to use it). Or try burning to folders instead of discimage...
    Jan 2009
    http://www.corel.com/corel/pages/index.jsp?pgid=800161&ppid=400012 Did you run the software patches? My Movie Factory 6 did NOT work properly from the CD out of the box, and I had to run some updates to get it to work right.
  6. Member DB83's Avatar
    Jul 2007
    Well we have not heard from the OP to see if the suggestion about shorter paths has had any affect.
    Corel/Ulead always release patches but did you also have the same issue ?
