I have a 42"plasma( Samsung S42AX-YB01). It does not come on. on the power button, when I plug in the tv, I get 4 red LED flashes then it pops/clicks continuously. I have replaced the power board bypassing the capacitor issue. When I called Samsung they said my tv did not fall under the bad capacitor issue as it was plasma...there was a bad cap that I replaced on the old board. I replaced the board just to make sure there wasn't a problem with other caps I couldnt see an issue with...
Any help I would GREATLY appreciate it!!!
thanks!
What is the Samsung model number on the back of the TV?
The number you gave seems to be a panel part number. -
Have you attempted Samung contact for a blink chart? Each make and model can vary on chart. Here is one for a idea:
1 - blink STV 5v sense DG Board
2 - blinks 15v SOS D Board
3 - blinks 3.3v SOS D Board
4 - blinks Power SOS P Board
5 - blinks 5v SOS D Board
6 - blinks Driver SOS 1 SU / SD / SC Boards (SC energy recovery circuit)
7 - blinks Driver SOS 2 SU / SD / SS Boards (SC floating voltage area)
8 - blinks Driver SOS 3 SS Board (SS energy recovery circuit)
9 - blinks Panel Config. SOS
10 - blinks Sub 5v SOS / Main 3v SOS DG Board DTV 9v SOS / Tuner Power SOS
11 - blinks Fan SOS PB Board
12 - blinks Sound SOS H Board
13 - blinks Communication error DG Board with IC8001 (Pesks Lite 2)
I/O light flashing..help..need to connect HT to comp.
By techspark in forum Media Center PC / MediaCentersReplies: 7Last Post: 2nd Mar 2011, 12:30 -
Cyberhome CH-DVD 400 green light flashing
By Kalash109 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 31st Jan 2010, 02:59 -
Blank DVDs and flashing light on the DVD drive
By timmus in forum DVD & Blu-ray WritersReplies: 5Last Post: 27th Jan 2010, 22:31 -
SOLVED Vegas 8.0, how can I make a light bulb flashing?
By sdsumike619 in forum EditingReplies: 2Last Post: 25th Apr 2009, 17:21 -
Samsung HR 720 DVD light flashing and the unit will not turn on
By Stwatson in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Apr 2008, 07:55
