I would like to know if I can improve the performance/speed of VirtualDub and AviSynth scripts.
A typical script I use is something like this:
I'm using VirtualDub 1.8.8 and Avisynth 2.58 for my scripts to convert to huffYUV avi.Code:LoadPlugin("...\MeGUI 2050 x86 - 2011-08-30\tools\dgindex\DGDecode.dll") LoadPlugin("...\MeGUI 2050 x86 - 2011-08-30\tools\avisynth_plugin\ColorMatrix.dll") LoadPlugin("...\MeGUI 2050 x86 - 2011-08-30\tools\avisynth_plugin\TIVTC.dll") mpeg2source("E:\Clips\Movie.d2v", cpu=4, info=3) ColorMatrix(hints=true, interlaced=true, threads=0) Bifrost(scenelumathresh=2, interlaced=true) TFM(order=1, slow=2, pp=5, clip2=TDeint(mode=2, blim=100, mtnmode=3, type=3)) TDecimate(hybrid=1) Crop(8, 0, -8, -0) Spline36Resize(640, 480)
Is there any way to speed up the conversion process? For instance, a change in the script, multithreading, etc.
I don't think It's my PC that's slowing it down, I have a quad-core with hyperthreading, 16GB RAM, and the hard drives I use for editing are in RAID 0 with a sustained throughput of over 250 MB/s, so I think there must be something else.
On the other hand, is this simply as fast as the script will run?
How fast is it running? Mpeg2Source(CPU=4) is pretty slow. Is that a DVD source? An HD source? I don't know about BiFrost() but the rest of the filters are pretty fast. You can try switching to the multithreaded build of AviSynth and using SetMtMode(). What kind of CPU usage are you seeing?
I typically get around 50-60 fps and the source is NTSC MPEG-2 video clips. BiFrost() is used to remove some of the rainbowing in the video. My CPU usage rarely goes above 20%, usually sits around 15-17% usage.
Does it matter which order the filters are in the list? Should I remove the "CPU=4" part of the Mpeg2Source(CPU=4) line? Really, I don't know what it's for anyway, still a noobie here.
Just so U know, I have a Core i7 2600K and think that it should be much quicker than it is. -
Running single threaded on a random NTSC m2v file (i5 2500K, quad core, no HT) I was getting about the same speed as you -- 70 fps. Eliminating TFM() and TDecimate() got the speed up to about 120 fps. Further eliminating CPU=4 got the speed up to 200 fps.
Running with 4 threads the full script ran about 80 fps. Eliminating TFM() and TDecimate() ran about 220 fps. Further eliminating CPU=4 ran about 440 fps.
Multithreaded script:
I tried playing around with the number of threads but didn't see much difference with the full script. I guess you're stuck.Code:SetMtMode(5,4) Mpeg2Source("VTS_01_2.demuxed.d2v", CPU=4, Info=3) SetMtMode(2) ColorMatrix(hints=true, interlaced=true, threads=0) Bifrost(scenelumathresh=2, interlaced=true) TFM(order=1, slow=2, pp=5, clip2=TDeint(mode=2, blim=100, mtnmode=3, type=3)) TDecimate(hybrid=1) Crop(8, 0, -8, -0) Spline36Resize(640, 480) -
Thanx for the script and trying it out yourself for comparison.
Changing the SetMTMode() variables does make a difference, however on small clips (up to 5 mins.) it's hardly even noticeable. I'm certain that it will improve things on much longer video takes.
Also, I'm using the integrated graphics on the 2600K, (don't have my new video card yet), so I guess some of the resources are split between encoding and display, for now. Should be interesting when I get the video card and start to OC the system.
jagabo, are you OCing and at what speed? What video card do you have (if any)? -
AviSynth & VirtualDub - Comfortable ways to create avs-files?
By klischee in forum EditingReplies: 7Last Post: 28th Oct 2010, 16:20 -
What AviSynth filters and settings could I use to improve this old film ?
By chipsndukes in forum RestorationReplies: 38Last Post: 12th Aug 2009, 17:09 -
Improve MPlayer performance / video smoothness
By alexandre_fs in forum Software PlayingReplies: 2Last Post: 15th Jan 2009, 15:38 -
Avisynth + Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 21st Dec 2007, 05:57 -
Using avisynth instead of virtualdub?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 12th Jul 2007, 10:23
