Hi there !
I have here an "avi" file, but I think the extension is not correct, which I can't play on my popcorn media device.
Can you please help me identifying the media, as well as let me know how to convert it in something more standard ?
Many Thanks !Code:General Complete name : W:\Stargate SG-1.S2E01E22\Stargate SG-1.S02E02 - CORRUPTED - La tête à l'envers.avi Format : OGG File size : 351 MiB Duration : 42mn 26s Overall bit rate : 1 157 Kbps Video ID : 0 (0x0) Format : MPEG-4 Visual Format settings, BVOP : Yes Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Codec ID : DX50 Codec ID/Hint : DivX 5 Duration : 42mn 26s Width : 640 pixels Height : 352 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Writing library : DivX 5.0.2 (UTC 2002-05-16) Audio #1 ID : 1 (0x1) Format : Vorbis Format settings, Floor : 1 Duration : 42mn 26s Bit rate mode : Constant Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Writing library : libVorbis 1.0 RC3 (UTC 2001-12-17) Language : French Audio #2 ID : 2 (0x2) Format : Vorbis Format settings, Floor : 1 Duration : 42mn 26s Bit rate mode : Constant Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Writing library : libVorbis 1.0 RC3 (UTC 2001-12-17) Language : English Menu 00:00:00.000 : Attaque sans motif 00:03:46.840 : Bilan médical de Carter 00:08:58.360 : Le secret de Cassandra 00:14:57.160 : Un assassin 00:23:47.840 : La Tok'ra 00:28:51.640 : Tenté d'y croire 00:31:50.760 : Enceinte de sécurité violée 00:34:52.040 : Tentative de réanimation
Closed Thread
One similar thread is enough. It's an ogm. Continue in https://forum.videohelp.com/threads/342874-My-popcorn-C200-can-t-play-this-file-and-can...33#post2136033 .
Identifying/Resolving issues with AVI file
By mce206 in forum Newbie / General discussionsReplies: 2Last Post: 15th Dec 2011, 14:47 -
identifying codec.......
By nodollas in forum Video ConversionReplies: 16Last Post: 30th Sep 2011, 12:48 -
Identifying OS on DVR HD
By juststarting in forum ComputerReplies: 6Last Post: 24th Feb 2010, 00:29 -
Problem identifying file...
By extreme85 in forum Newbie / General discussionsReplies: 8Last Post: 15th Aug 2009, 10:23 -
Tools for identifying RM/RMVB file?
By ohboy888 in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2008, 07:26
