Results 1 to 16 of 16
    Jan 2012
    Oahu, Hawaii
    Hello!
    I really need help on cpu upgrades. While searching through this forums i cam across an "Intel Core i7 Processor" Which is said that it can encode videos fast. So Im going to buy it, but the part is i don't know if it can fit my computers. Below is my computers that I have.
    * eMachines: et1831, Intel Celeron 450
    * Toshiba: Satellite L505-S6946, intel core 2 duo
    * Dell: Inspiron e1705, Intel core 2 duo
    I have other dell computer don't know if they are upgraded also because they are old. I been searching and I couldn't find one. thanks to anyone who helps me!
    canada
    For an Intel Core i7 Processor you will have to buy a new motherboard,ram and possible videocard depending if you use on board/cpu graphics,in other words no.
    Jan 2012
    Oahu, Hawaii
    I don't mind getting another one for the toshia laptop. In otherwords which on is good for the toshiba laptop?
    canada
    You can't upgrade laptop cpu,gotta buy a new laptop.
    Jan 2012
    Oahu, Hawaii
    What Laptops would you recommend? I don't want to get a desktop.
  6. I'm a Super Moderator johns0's Avatar
    canada
    Maybe someone here can recommend what laptop you should get depending what you need to do with such as gaming,encoding,etc..
  7. For example:
    Try checking at newegg
    DELL Alienware M17x R3 Intel Core i7 2670QM(2.20GHz) 17.3" 8GB Memory 750GB HDD AMD Radeon HD 6870M Notebook Part#: AM17XR3-6579STB
    Operating System: Windows 7 Home Premium 64-Bit
    Optical Drive Type: DVD±R/RW
    Resolution: 1600 x 900
    Model #: AM17XR3-6579STB
    Item #: N82E16834200355
    Now: $1,549.99
  8. Member rr6966's Avatar
    May 2004
    Cincinnati, Oh, USA
    I can't imagine using a laptop for any serious encoding, that may take hours. I would buy a good i7 2600k sandibridge computer, or build one. It will be way cheaper and better than using a laptop.
    Jan 2012
    Oahu, Hawaii
    I would like to build a laptop. Reasons why, is because I go to alot of places. I travel all around mostly everyday and I usually bring my laptop around. I tired looking for one but they already come built in with core i7. I want to find a laptop that has a core i7 socket (that doesn't come with intel core i7) and cheap. Then buy the parts for it. I.e Intel Core i7, GPU, Ram, Etc.
    Jul 2001
    A laptop is not a very good choice for an encoding machine. I'd build a new desktop for your encodes and leave your existing laptop just for playback.
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
  11. Originally Posted by Datson View Post
    Building your own laptop is not really an option, especially with an i7 processor. Even the major players are having a time with getting battery life to reasonable times for the i7, along with dissipating the heat from all the processing power. Doing serious video on a laptop seems to be more of a wish rather than a reality. Give the major manufacturers some more time. They may get a reasonable working solution, given the number of people that want the same thing as you.
  12. And unless you have access to power line everywhere you go your laptop battery life would be unrealistically usable for anything else.
    Jan 2012
    Oahu, Hawaii
    I have a power line everywhere I go. I just need to find one.
    Aug 2006
    There are such things as bare-bones laptops, but pardon my frankness, building a laptop is clearly out of your league at present. If you do not know that you can't upgrade the CPU on any of the systems you currently own to an i7, you have a very long way to go before you know enough to build your own laptop.
    Desktops are much easier to build yourself. Laptop parts tend to be proprietary, are not easily interchangeable, and there are more compatibility issues. Plus, power and cooling are going to be a much bigger problem than would be the case with a desktop. You won't be able to pick any i7 you want. You will be limited to mobile i7 CPUs compatible with your motherboard.
    Look at high-end gaming laptops like Sager or Alienware that allow you to pick something close to what you want from amongst several models and configure the options from a list.
    May 2006
    My $0.02. Start over. I'm big on HP workstations. They are a real deal used. Search ebay "HP XW8600 2x Quad-Core Xeon E5450 3.0GHz 8Gb 2x147Gb 15k SAS FX3700" $600 delivered. You will need to add Win 7 ($120) and a system SATA drive ($75). You get 8 3.0 GHz cores with a 1333 bus, 15K Video RAID, 8Gb RAM and a nice Quadro card. What's not to like.
    Depends what the definition of the word inhale is.
    Jan 2012
    Oahu, Hawaii
    I really don't want a desktop,But Luckily A friend of mines gave me his Sager NP8150, 2Gen Intel Core i7, 8Gb Memory, 500 GB HDD for $300. Thanks for answers.
