I realize this may not be the intended purpose of the tool, but I am trying to author a DVD with a bunch of AVI titles into a single SD-DVD. When I use MultiAVCHD (4.1) I get a seperate DVD folder for each file/title. When I author an AVCHD or BD disk, the titles are combined onto one disk. Is there some setting I am missing?
Thanks,
Jeff![]()
I had this same issue with down converting home movies from hd to vobs...I can't rightly tell you what you can do in Multiavchd to get what you want but I can say there's a much easier app to use that works every time
FAVC
simple and works like a charm -
Thanks. I did find FAVC and DVD Flick after I posted my question. FAVC works well, but limits the menu to only 8 titles. DVD Flick doesn't do that, but I don't like the paging style menus. I like the ability to scroll through all the titles. Maybe, that's just not possible on DVDs like it is on BD and AVCHD disks? I know I am being picky considering all this is free software, so I probably will make due with this, but MultiAVCHD's menu options are just wonderful.
Thanks again,
Jeff -
Anyone have an answer for how to get multiple videos on one disk with MultiAVCHD? it keeps making multiple one file disks instead of putting all the files on one disk.
multiAVCHD misses multiple audio or subtitles tracks
By Japo in forum Authoring (Blu-ray)Replies: 2Last Post: 24th Jun 2011, 19:26 -
Multiple VCD to single DVD
By Ryan Kelly in forum MacReplies: 7Last Post: 5th Apr 2009, 12:15 -
All-in-one program for multiple avis to dvd with menu and good quality?
By Yaeli in forum Authoring (DVD)Replies: 9Last Post: 4th Sep 2008, 16:01 -
Multiple AVIs to one DVD
By 64RedMustang in forum Authoring (DVD)Replies: 7Last Post: 13th Sep 2007, 19:42 -
multiple AVIs to DVD
By exekutive in forum MacReplies: 2Last Post: 11th Jun 2007, 10:49
