Hi, This is the first movie i've ever tried to backup. I use Pinoy's guide. When I get to the part to cut the movie into sizes that can fit onto two discs, I pick the length of the movie i want to put on the first disk, when i press OK I get an error saying that a "read error occured at ....", has anyone had this problem, Does anyone know a good fix to it????
Thanks in advance.
I also get this error but it does not seem to be a problem. Just close the error dialogue and proceed (clicking run or whatever). It still correctly cuts the video.
Thanks alot man, Seems to be running fine. Will come back if there another problem that i can't figure out.
Thanks again -
I also get this error. It does not seem to be a problem in Win2000. But I just can't get it to work with latest TMPGEnc and WIN-XP-pro. Everytime I click Run the same error message pops up! Very frustrating!! :evil:
Any help is greatly appreciated!
Are there any software that will SIMPLY cut and merge *.mts without re-enco
By skydutch in forum EditingReplies: 1Last Post: 12th Nov 2011, 04:04 -
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 09:41 -
How can I cut/edit/merge/add some info/add hardsubtitle in one media (DVD)?
By roUndy_sh in forum EditingReplies: 8Last Post: 26th Dec 2010, 17:45 -
Cut and Merge MPEG-2 Files
By flash_49 in forum EditingReplies: 8Last Post: 12th Feb 2010, 10:03 -
How the cut and merge function works on your dvd recorder?
By v1p0n3 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 5th Jan 2010, 05:59
