I would like to be able to put a picture in my DVD so that when it is in a computer the folder comes up with that picture. I also thought that at one time there was a way that if one pressed pause on the remote rather than the still image at that time it would come up with the picture perhaps something in a J_Folder. Thanks
You're thinking of the "Jacket Picture" feature. These are specially-encoded MPEG I-frames (not jpeg), put into the JACKET_P folder (just off the root).
Unless you have an encoding/authoring app that specifially supports the creation of jacket pictures, it probably won't be created correctly. And even if it is created correctly, the Jacket Picture feature is only supported on some models of players.
In a computer, you could put jpgs in another folder and have autorun set to open the folder, etc. (assuming your computer is still set to allow autorun - a big if).
Scott -
Thats right Jacket_P how easily it is to forget these things. I have made two DVDs and just put the jpg file in the main root directory (not in a folder) The DVDs each ran correctly in two different DVD players. Should this be okay or will DVD players throw a fit when it sees these files that don't belong? PS thanks for your response PS thanks for the response Scott
The dvd will play ok as long as you add the folders and burn as a dvd video.
How a given DVD player plays DVD-Video is tied to how compliant the dvd is to the DVD-Video spec. This includes:
Codecs (MPEG2 SP&ML, MP@ML, MPEG1, lpcm,ac3,mp2,dts)
Layout (VIDEO_TS.IFO, .VOB, .BUP, etc)
Filesystem (UDF 1.02, VIDEO_TS & AUDIO_TS folders, <=1GBmax each file, etc)
...many more specifics
How a given DVD player plays jpegs is totally at the whim of the DVD player (and chipset) manufacturer.
(Note: DO NOT put them in either the VIDEO_TS or AUDIO_TS folders!)
Jacket Picture is an optional adjunct to the DVD-Video spec.
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 20:09 -
minimum blu-ray folder structure
By tommyjw in forum Newbie / General discussionsReplies: 5Last Post: 12th Aug 2010, 21:51 -
Blu-Ray T.V. Folder Structure & WMC
By carlos28355 in forum Blu-ray RippingReplies: 0Last Post: 3rd Jun 2010, 15:09 -
Make Blu Ray folder structure w/o re-copying the m2ts file
By stew181 in forum Authoring (Blu-ray)Replies: 3Last Post: 9th Jan 2010, 11:14 -
Extracting jpg photos from the ITEM####.dat files in the VCD segment folder
By H-Man1953 in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2007, 07:54
