Hello everyone,
I've been having the same problem for months now. I found some threads on dvd audio sync problems, but those problems were all different from mine and the threads several years old.
The problem: I'm editing videos with VirtualDub and Avisynth. The resulting Xvid Avis work fine in several media players, but after converting them to dvd format, the audio is slightly off. The amount to which it is off differs. I've tried authoring with Avs2dvd and DVDFlick which seem to get the best ratings by users, but the problem remains the same.
Can anyone help? If you need more information, please let me know - at the moment I don't know what to look for because this happened with so many different files. Thanks!
Can you post the details from the avi xvid? Use mediainfo, view->text.
Or maybe try export to another format with virtualdub, like lossless huffyuv or lagarith(huge files but no quality loss) -
Hm, the file is already huge. How would that exporting work? Can DVDFlick handle those file types? Anyways, here's the info:
Format : AVI
Format profile : OpenDML
File size : 2.27 GiB
Duration : 49mn 18s
Overall bit rate : 6 593 Kbps
Writing library : VirtualDub build 32842/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Custom
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 49mn 18s
Bit rate : 5 043 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.183
Stream size : 1.74 GiB (76%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Codec ID/Hint : Microsoft
Duration : 49mn 18s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 542 MiB (23%)
Interleave, duration : 33 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Audio/video fine on PC, out of sync on Mac
By scrolls in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2012, 21:48 -
Xbox 360 streaming -- audio of out sync (fine on computer)
By ycrazyy in forum Newbie / General discussionsReplies: 0Last Post: 19th Jan 2010, 09:42 -
Video is out of sync (audio is fine)
By MaxNH in forum Newbie / General discussionsReplies: 4Last Post: 29th Dec 2009, 10:55 -
Problem fine tuning audio sync
By spark001uk in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2009, 14:02 -
No audio w/ MP4 to AVI conversion in 0.0.9y (worked fine in 0.0.9v)
By rmerkley in forum ffmpegX general discussionReplies: 6Last Post: 8th Jun 2008, 23:16
