Hi,
Found this site after hours of comparing cards and pvrs and I figured I should get some advice on what way to go about getting my vhs tapes on my computer. I wasted 10 bucks on one of those easycaps and the res was just bad. I used 2 differnt programs and neither were not that great. I looked at the canopus ones but they were a little bit too pricy for me*I only have 6-7 vhs tapes). Could someone recommend a card or external to use? I am using a sony vcr/dvd with only rca outputs.
Hi Teebo and welcome.
To the left of this post is a Column called Video Help.
Check out LISTS - CAPTURE CARDS
Then check out HOW TO - CAPTURE
You'll need to a fair bit of reading.
Use the search facility to help cut down on the choices.
Cheers.Last edited by pcspeak; 21st Jan 2012 at 21:29.
Will do. Should I be concerned that a lot of the card reviews are from 2003-05?
OOPS! My apologies. It's been a while since I read up on VHS capture.
In a second PC running Windows XP SP2 I have a Leadtek 'Winfast TV2000 XP Deluxe' card.
It works well.
Just completed 5 conversions to AVI for the family.
My first choice because I'm in Aussie.
http://www.pcmediacenter.com.au/forum/topic/44172-capture-from-vhs/
Other reading.
http://www.articlesbase.com/e-learning-articles/how-to-transfer-movies-from-vhs-to-dvd-5226401.html
http://forums.adobe.com/message/3437467
Hope this is more help.
Cheers.Last edited by pcspeak; 22nd Jan 2012 at 01:03. Reason: http://www.video-2-pc.co.uk/ removed. Didn't realize 2 of 3 software items are freeware.
Compare VHS to computer vs cheap HD to computer ending in youtube post
By gittarpikk in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 12:06 -
Need advice quick, 25 FLV/EXE convert to DVD
By SINBAD09 in forum Newbie / General discussionsReplies: 5Last Post: 27th Jul 2009, 05:23 -
any advice on quick and dirty vhs conversion to dvd?
By cheap in forum Newbie / General discussionsReplies: 0Last Post: 28th Jun 2009, 19:29 -
I have a deal for a Sony HDR-HC3 for 350$ CDN, need quick advice
By DavidOBE in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 26Last Post: 29th Dec 2008, 12:35 -
Maybe some quick advice
By jfharper in forum ProgrammingReplies: 0Last Post: 9th Nov 2007, 22:49
