Hi there,
A quick search shows that there were no discussions on Despot Avisynth plugin recently.
I wonder if there is another method to remove spots or nobody cares anymore.
Here is a link to a clip of mine http://www.mediafire.com/?g9ex0567vtucrgd (22Mb only)
There you can see a lot of white and black spots (mainly white) in almost every frame. Fortunately every spot appears for one frame only.
So I gave Fizick's DeSpot a try, but .. suprise... it seems to not work at all ! Even for small spots on a flat surface (wall) which lacks other details.
here is the line I tried : DeSpot(p1=35, p2=14, interlaced=false, pwidth=20, pheight=20, mthres=25)
(yes, off course I loaded the DLL first
Any ideas ?
Thanks a lot !
Results 1 to 30 of 48
Best wishes,
UP -
This removes most of them:
A modification of RemoveDirt(). Unfortunately, some of the worst ones (frames 63 and 96) are still there.Code:function RemoveSpots(clip input, bool "_grey", int "repmode") { _grey=default(_grey, false) repmode=default(repmode, 16) clmode=17 clensed=Clense(input, grey=_grey, cache=4) sbegin = ForwardClense(input, grey=_grey, cache=-1) send = BackwardClense(input, grey=_grey, cache=-1) alt=Repair(SCSelect(input, sbegin, send, clensed, debug=true), input, mode=repmode, modeU = _grey ? -1 : repmode ) restore=Repair(clensed, input, mode=repmode, modeU = _grey ? -1 : repmode) corrected=RestoreMotionBlocks(clensed, restore, neighbour=input, alternative=alt, gmthreshold=70, dist=1, dmode=2, debug=false, noise=10, noisy=12, grey=_grey) return corrected } AviSource("example.avi") ConvertToyV12() RemoveSpots()
You should be capturing and compressing as YUY2, not RGB. You have some AGC problems too.Last edited by jagabo; 7th Jul 2012 at 11:56.
My Name Is Firas, I am a new memberand I want your help for the best program or filter to remove
spots of my Video, I have spend All the last time searching for which is the best prorgram or despot filters but i have no results. I was try Spotremover for Virtualdub with (no_dups_with_SpotRemover) Code but it's not work at all. I tried to use the code by (jagabo) but I am not Sure that I have use it Correctly.
please help me by your knowlage to give me advice "whats is the best choise does U use". thanks Alot For you are reading this massage
thank for you reply, my videos quality is same as Umen Pich's video (Example) http://www.mediafire.com/?g9ex0567vtucrgd its an old movies
how I can use the code:
clmode=17
return corrected
ConvertToyV12()
RemoveSpots()
and which program I have to use? -
What exactly is the problem you're having? Are you familiar with how AviSynth works?
RemoveSpots() got rid of most of the small spots in your sample. It left some big spots in frames 63, 71, and 96. You could try playing with the RemoveSpots() parameters but I used ReplaceFramesMC() instead to interpolate a new frame from the frames before and after:
You'll need to download and install all the filters those function rely on (maybe others):Code:function RemoveSpots(clip input, bool "_grey", int "repmode") { _grey=default(_grey, false) repmode=default(repmode, 16) clmode=17 clensed=Clense(input, grey=_grey, cache=4) sbegin = ForwardClense(input, grey=_grey, cache=-1) send = BackwardClense(input, grey=_grey, cache=-1) alt=Repair(SCSelect(input, sbegin, send, clensed, debug=true), input, mode=repmode, modeU = _grey ? -1 : repmode ) restore=Repair(clensed, input, mode=repmode, modeU = _grey ? -1 : repmode) corrected=RestoreMotionBlocks(clensed, restore, neighbour=input, alternative=alt, gmthreshold=70, dist=1, dmode=2, debug=false, noise=10, noisy=12, grey=_grey) return corrected } function ReplaceFramesMC(clip Source, int N, int X) { # N is number of the 1st frame in Source that needs replacing. # X is total number of frames to replace #e.g. RX(101, 5) would replace 101,102,103,104,105 , by using 100 and 106 as reference points for mflowfps interpolation start=Source.trim(N-1,-1) #one good frame before, used for interpolation reference point end=Source.trim(N+X,-1) #one good frame after, used for interpolation reference point start+end AssumeFPS(1) #temporarily FPS=1 to use mflowfps super = MSuper() backward_vec = MAnalyse(super, isb = true) forward_vec = MAnalyse(super, isb = false) MFlowFps(super, backward_vec, forward_vec, blend=false, num=X+1, den=1) #num=X+1 AssumeFPS(FrameRate(Source)) #return back to normal source framerate for joining Trim(1, framecount-1) #trim ends, leaving replacement frames Source.trim(0,-N) ++ last ++ Source.trim(N+X+1,0) } AviSource("example.avi") ConvertToYV12() #RemoveSpots() requires YV12 RemoveSpots() ReplaceFramesMC(63,1) ReplaceFramesMC(71,1) ReplaceFramesMC(96,1)
http://avisynth.org.ru/mvtools/mvtools.html
http://home.arcor.de/kassandro/RemoveDirt/RemoveDirt.htm
You still have a problem with color and brightness wandering around. But that's probably better addressed in another thread. -
It will be uncompressed YUY2, so then you usually feed the script to an encoder. It depends on the final format goal you desire
If you don't know how to use avisynth , read the beginners' guide
http://avisynth.org/mediawiki/Main_Page
http://avisynth.org/mediawiki/First_script
http://avisynth.org/mediawiki/Getting_started -
I have not understand any idea can you tell me the step to get a video without a spots please?
This is not a good project for beginners because of the complexity of the script and the assortment of third party filters used. But here are the basic steps:
1) Install AviSynth.
2) Downloaded the other filters I listed. Open the archives and copy mvtools2.dll and RemoveDirt.dll to AviSynth's Plugins folder. Some other filters may be required but I don't know what they might be. If you get an error message later on it will tell you what filter is missing.
3) Use Notepad to make a text file with the script I listed above. Change the extension of the file from .TXT to .AVS. If your AVI file has a different name change the script to use that name. Or rename the file to match the script. If you don't use the exact same file as your sample the ReplaceFramesMC() lines will have to change to match the frames that need replacing.
4) Open the AVS file with a video editor or encoder. VirtualDub is a good program to use to test your AVS scripts. Use File -> Open Video File to open the AVS script. If all is working properly you can encode.Last edited by jagabo; 7th Jul 2012 at 18:42.
Thanks a lot for your advice.
I did what did you tell me exactly:
1 . I Intalled AviSynth.
2 . I downloaded the filters (mvtools2.dll and RemoveDirt.dll) and many others dll, and I copied them to AviSynth's plugins folder.
3 . I used Notepad to make a text file with the script that you listed above as AVS file, and I did what is the correct for names to match the script as you Explain above.
4 . I opened AVS file, Then I opened VitrualDub Program with Spotremover 355 filter with the video of Course.
But Actualy it doesn't work!... What I have to do?
Here is two samples of my videos.Last edited by the Prodigy; 9th Jul 2012 at 06:40.
Spot removers won't work on those videos because they have been through extremely strong temporal filters. Spot removers work by looking for spots that occur on only one frame. The temporal filter used on those clips has caused the spots to span several frames (ie each frame of the video is a combination of several of the original film frames).
that's meane I have to open AVS File then I have to open VertualDub Program and play the video, then Export it. is that Right?
First of all, you don't need the AviSynth script if you're going to use the SpotRemover plugin in VirtualDub (although using both might remove more spots).
If you're going to use VirtualDub to encode your video (using an AviSynth script or not) you set up whatever filters you want, set up the compression codecs, then File -> Save as AVI. If you're going to use another encoder you just treat the AviSynth script as if it was a video file and supply that to the other encoder. For example, with the x264 CLI encoder:
Finally, as noted, those spot remover plugins will not work with your video.Code:x264 --crf 18 --output filename.mkv filename.avs
No, I won't use spotremover filter Any more because it's useless with this videos as all the last time I have been use It, I will only use virtualDub With AVS Script as I see It's results.
I tried this way but also It doesn't work, maybe because of incomplete the (*.dll) plugins Inside AviSynth plugins folder. I have (mvtools2.dll , RemoveDirt.dll and RemoveDirtS.dll). and I'm sure about them, because you tell me to download them. But what about the others (*.dll), Once you tell me there is anothers and maybe you will receive a massage about them but I didn't. Thanks for your kind...
When you open the AVS in VirtualDub (use File -> Open Video File..., not File -> Run Script...) you should get a message about what filter is missing. You use that information to track down what filters you need to download and install.
But once again, you're wasting your time with these particular videos. The AviSynth filters aren't going to remove the spots either. -
You need to get back to the original video -- before it's been through the temporal filter. Otherwise, I don't see any way to fix them unless you are willing to paint the frames by hand. Or write a very long script to copy bits of other frames to cover up each individual spot.
there is no original video, the way of scripts is difficult for me, and I'm ready for the manualy way but how?
"manually" means painting frame by frame and cleaning up the spots e.g. in photoshop or after effects
you can copy parts of "clean" frames to cover up spots on "dirty" frames , but sometimes there are areas where there is no "good" frame to derive information from, and you have to reconstruct it almost from scratch
This is a lot of tedious work -
Hi Everyone, I have a problem to loading AVS script with Virtualdub for removing a spots, when I tried to run AVS File with the Encoder an Error massage appeared "there is no function of Clense" that's meanes there is a missing .dll, Is That Right? Could any body help me with URLs please?
I think cleanse comes with one of the removegrain filters (there are a few). Unfortunately I can't recall exactly which version is the required one . It might be 1.0b
http://forum.doom9.org/showthread.php?t=144235
http://avisynth.org/mediawiki/Removegrain -
Unfortunately its not work and there is same Error massage> Maybe because of using this code for spot removing:
clmode=17
return corrected
start+end
super = MSuper()
RemoveSpots()
ReplaceFramesMC(96,1) -
But those functions rely on other .dlls. clense is most definitely part of removegrain . Make sure you have removegrain.dll in your plugins folder (I'm not sure which removegrain version)
I think it's this one
http://home.arcor.de/kassandro/RemoveGrain/RemoveGrain.rar -
Yes Now maybe its work because it's appeard a new error: there is no function named "SCSelect" How I could pass it?
FLV audio out of sync, can't work VirtualDub w/ FLV plugin
By ZantarV in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 11:51 -
Cant Get Vista Media Center to Work Even with My Movies Plugin
By jet757f in forum Media Center PC / MediaCentersReplies: 18Last Post: 6th Jul 2008, 18:40 -
DeSpot Filter Question
By mcpogue in forum RestorationReplies: 1Last Post: 27th Feb 2008, 15:14 -
Nero FLAC plugin doens't work
By happydog500 in forum AudioReplies: 0Last Post: 4th Jun 2007, 13:07 -
Problems with Fizick's Despot.
By 1gnition in forum EditingReplies: 6Last Post: 23rd May 2007, 07:10
