I have a Canon HF G10 with Canon shotgun mic. I recently bought a Sony ECM-AW3 wireless mic for it as well. Since I am recording outdoor hunting videos, I want to use both the shotgun mic and the wirelss mic. The shotgun mic overrides the wireless mic when both are connected. Is there something that I am missing or is this possible to run both mics together?
The Canon HF G10 doesn't have a shotgun mic. Do you mean the XA10? That model has a built in mic/line mixer allowing two mics to be used.
For the G10, look at the external Beachtek DXA-2T.Last edited by edDV; 21st Jan 2012 at 18:52.
http://www.kiva.org/about -
I have an external canon shotgun mic that attaches via the mini hot shoe.....
Are you saying that the only way to use both the hot shoe (with a shot gun mic) and a wireless mic is to use an external mic/line mixer?
Yes* if the hot shoe mic also has a wired output. Most don't.
You should have bought the XA-10 that is the same camcorder with built in 2 mic adapter. You may be able to trade up. Otherwise, add the Beachtek.
* I don't have your camcorder so you should read the manual and test it. Similar camcorders cut the hot shoe mic when an external mic is plugged in.Last edited by edDV; 23rd Jan 2012 at 20:29.
XLR to 3.5mm shotgun mic
By Gerrysw in forum AudioReplies: 10Last Post: 30th Dec 2011, 17:36 -
Shotgun Mic for Canon Vixia HF S20
By amriteshvara in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 18th Jul 2011, 14:37 -
Shotgun mic for Sony DVD-405
By gmcman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th May 2010, 21:30 -
Looking for a cheap shotgun mic
By 872156 in forum AudioReplies: 8Last Post: 13th Jul 2009, 21:25 -
Canon XM2/GL2: Wireless Lavalier Mic Question
By Xenon77 in forum Newbie / General discussionsReplies: 9Last Post: 29th May 2009, 20:25
