I've tried contacting both companies for help because my uploads are transcoded by YT with black bars, but the problem remains unresolved.
The files are 1280x720P 16:9
Because of a problem I'm having with recent versions Samsung's Intelli-studio software for uploading caused me to use YT's uploading page instead. The resulting videos have black bars whereas I-s ones turned out well.
Older versions of I-s are buggy and have limited editing so I'm thinking of shelling out for a software that I could transcode these .mp4's so that I could use YT's uploader and not see the black bars in the finished product.
Samsung HMX-H106SN/XAC HD Camcorder -
General
Complete name : D:\Samsung\Withrow Moraine\HDV_0595.MP4
Format : MPEG-4
Format profile : JVT
Codec ID : avc1
File size : 131 MiB
Duration : 1mn 30s
Overall bit rate : 12.1 Mbps
@sec : UNG
Video
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=3, N=15
Codec ID : avc1
Duration : 1mn 30s
Bit rate mode : Variable
Bit rate : 12.0 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 3.161
Original display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 59.940 fps
Minimum frame rate : 59.920 fps
Maximum frame rate : 59.960 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.217
Stream size : 130 MiB (99%)
Title : SAMSUNG AVC
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1mn 30s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 1.38 MiB (1%)
Title : SAMSUNG AAC
Language : EnglishSamsung HMX-H106SN/XAC HD Camcorder -
YouTube is going to cut the framerate in half, as they don't publish 59.94fps videos, but that doesn't explain them adding black bars to it. Do you have a YouTube link so we can see? Are they squishing the video, or are they covering part of it with the black?
w/YouTube in Mozilla Firefox
w/Intelli-studio
The first link was May 2011 and still transcodes uploads like that in Jan 2012Last edited by zoomie; 21st Jan 2012 at 18:03.
Interesting. It's not even adding the black bars; that's being done by the player. Your video becomes such resolutions as 1280x404 and 1920x608. I suspect it can be repacked into a different container, one that YouTube handles better, but if it's possible someone else will have to instruct you how.
As for your original question, you don't have to pay good money to convert it to a different format as there are plenty of freeware programs that can do the job,. Maybe try XviD4PSP or XMediaRecode to convert your MP4 to an XviD AVI for upload to YouTube. While you're at it, halve the framerate to 29.97fps, if possible. -
Thank-you manono for your time and efforts in helping me make sense of this.
I like the repack idea, and I like free, will have a go at the softs you suggest.
This is the best site of its kind in the WORLD!
Newbie: List of Q's, Edit GoPro videos (MP4 and H264) and upload to youtube
By adamsnez in forum Newbie / General discussionsReplies: 3Last Post: 20th Feb 2012, 16:35 -
youtube upload without transcode
By VirtualDoobMon in forum Video Streaming DownloadingReplies: 1Last Post: 28th Oct 2011, 12:09 -
Converting MiniDV from Samsung SCD103 camcorder
By rangecon94 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 9th Feb 2011, 23:05 -
Trouble converting video to upload to YouTube
By Lassar in forum Newbie / General discussionsReplies: 10Last Post: 30th Jan 2010, 11:52 -
Converting MPEG4 .trp to h264 mkv
By Eric10301 in forum Video ConversionReplies: 13Last Post: 15th Jul 2008, 18:32
