I recently figured out how to download and decode and then recode a movie to a cd in vcd format. I went to download another movie but the silly thing is a text document. I used GRABIT as a newsgroup reader. Is there any way of changing or formating them so I don't have to redownload them again. If not how do I download them without them being a text document. I need help. Please send detailed info alse. I am a newbie. e-mail wdenney@nycap.rr.com thank you in advance.
wes[/u]
I have downloaded some strange extensions (.bmp for instance) in the past from various sites. Normally you just rename the file to .avi or .mpg and play it and all ok. (I'm not familiar with grabbit so sorry if this advice is bad!).
I have tried to change the file name but I am not sure I am doing it right. Plaesa give detailed info on how. Also in GRABIT there is an option to save articles without attachments as text. It is automaticly checked. If i uncheck it some articles won't even download. They are usually yenc articles but I know something is there because they are usually 10 to 20 mb files. I appreciate any help. thanks in advance.Originally Posted by cmacleo
wes
Decoding LG HB966TZ
By mikestar in forum Blu-ray RippingReplies: 2Last Post: 20th Oct 2011, 05:19 -
Help in CAVLC decoding
By krao in forum ProgrammingReplies: 0Last Post: 15th Jul 2010, 17:55 -
subtitles gone after decoding
By Meredy in forum SubtitleReplies: 1Last Post: 7th Jul 2009, 08:52 -
Cuda decoding
By b33rman in forum Blu-ray RippingReplies: 4Last Post: 28th Feb 2009, 09:46 -
DTS Decoding
By Neutral-Sage in forum AudioReplies: 8Last Post: 17th Nov 2007, 03:16
