Hello, my goal is to remove the internal subtitle from a DVD (folder), and add an external SRT. I have an MacPro with lion and use ffmpegX 0,0,9y-L with the newest binaries.
To do that, i followed this steps: I have demuxed the VIDEO_TS folder with DVD Demuxer because ffmpegx don't pull out the subtitles.
What i've got left is the m2v video file, the ac3 audio file and the subtitle files (that in this case i don't use).
In ffmpegx i'v added the m2v video file in the source format.
In the target format i select the DVD ffmpeg engine preset.
But when i try to add the external audio (AC3) file in the audio tab, and click preview in the options tab (below), i don't hear anything.
I have converter the AC3 to MP2 but nothing work. I also tried "invert mapping". What do i do wrong?
Second question: is it possible to add the external srt subtitle in the same step? Or have i to convert video/audio and add the subtitles separate?
You shouldn't add the .m2v and the .ac3 to the encoder, but use the Tools section instead.
In the Tools tab, select the Mux sub-tab.
Add the video and audio using the designated buttons.
Uncheck Author as DVD.
Mux. This will create a DVD-compliant MPG file.
Switch to the Author sub-tab.
Add the .mpg (from previous step) and .srt using the designated buttons.
Author. This should output a VIDEO_TS folder.
Open the VIDEO_TS folder in Apple DVD Player for a test drive.
Your subtitles may need to be manually activated to show.
Add audio won't work in audio menu.
By petwes in forum AudioReplies: 0Last Post: 21st Jan 2012, 07:59 -
CUDA don't work, why?
By lovelylisa in forum Video ConversionReplies: 38Last Post: 24th Jun 2011, 16:19 -
BD Sup to srt and why they don't work all that weLL.
By cal_tony in forum SubtitleReplies: 2Last Post: 4th May 2011, 09:17 -
How to add hardcoded subtitles to WMV using ffmpegX
By Vitoarc in forum ffmpegX general discussionReplies: 0Last Post: 12th Mar 2010, 11:42 -
I have a .ass but I don't know how to add it to a video...?
By darkzero297 in forum SubtitleReplies: 1Last Post: 23rd May 2007, 20:24
