Hello, Im back
Is there any program that can convert mkv to dvd and still get good quality and fast. I tried alot like convertxtodvd, dvdflick, avidemux, Still takes forever. I really need one.
Results 1 to 9 of 9
You need a faster cpu or a media device that supports mkv directly.
Convertxtodvd is fast. How long does a ~2 hour video take to convert for you? -
Get a media player that can play MKV files.
http://www.iboum.com/ -
Would it be faster if I just use MKVExtractGUI to take out the video and audio in different files then transcode or encode them to vob?
I have 2 computers. 1 desktop other laptop. Desktop: eMachines, Intel Celeron, 3GB Ram, 500GB. Laptop: Dell Insipiron e1705, Intel(R) Core(TM) Duo CPU T2250 @ 1.73 Ghz. Any Good?
Both Machines are slow when it comes to converting stuff .... (1-2 hours per 2 hour movie would be the normal speed)
The Celeron might have problems playing anything more than 720P esp if it was encoded in h264 codec.
The Core 2 Duo might have problems playing anything more than 1080P esp if it was encoded in h264 codec.
Of course you might try it out yourself to see what works for you. I would recommend using the laptop because it has a faster CPU.
A current intel machine Sandy bridge I-5 could prob do the same job in half to a third of the time.
what is the best and fast flv to dvd converter
By nusratjaveid in forum Video ConversionReplies: 1Last Post: 29th Jul 2010, 15:53 -
fast speed flv to dvd converter
By nusratjaveid in forum Video ConversionReplies: 2Last Post: 11th Jun 2010, 02:55 -
Fast Video Converter - quality of output?
By tonyp2 in forum Video ConversionReplies: 2Last Post: 13th Dec 2009, 16:08 -
Fast Divx to WMV Converter?
By Tchail in forum Video ConversionReplies: 5Last Post: 10th Dec 2007, 14:19 -
Fast converter for AVI to WMV???
By darren.Hall in forum ffmpegX general discussionReplies: 0Last Post: 3rd Dec 2007, 12:21
