Hi all,
Attached is a brief clip from The Money Pit (1986) ; around 15 seconds.
For anyone that knows how shots were composited back then, can you take a look at explain how a couple things were done? ...
When Shelley Long's double is running back and forth, you can tell that something isn't quite "right" / authentic. It almost looks like the lamp and door are layered above the footage of her running...?
I'm wondering how they achieved the far shot where both Shelley and Hanks' doubles are in the same shot; Hanks hanging from the top story and Long balancing so she won't fall. Again, something looks fake, and I'm sure it is. It looks like Long's body might be blue-screened...?
I obviously didn't know of the best place to post this; sorry all.
Thanks for your help and knowledge
- Justin
The 1st one is just a bad edit from 2 different takes . Go frame by frame in vdub, you will see a missing frame in the 1st pass, and the 2nd take has the door more slightly ajar
The 2nd one is usually done with harness & wires for that type of scene, then wires are removed in post production, but the shadows look wrong in that shot from the lighting in the scene . eg. When Shelly Long first comes to the edge, there is her corresponding shadow on Tom Hank's back ; which of course makes no sense -
I'm not certain, but I think part of the problem might've been where I made the cuts to shorten the clip. I attached a sample of the same scene but without editing. Are the same problems still there?
Hello i am new I have a Composite video question
By andres1981 in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2009, 23:44 -
Particular S-Video vs. Composite Question
By Anonymous4 in forum Capturing and VCRReplies: 12Last Post: 13th Jun 2009, 11:18 -
Canopus AceDVio composite capture problem (Svid works, but not composite)
By bfrandse in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2008, 10:55 -
Composite IN vs S-Video IN (using converter wire composite to s-video)
By goal in forum Capturing and VCRReplies: 2Last Post: 29th Mar 2008, 21:19 -
Philips DVP5960 HDCP Question /// HDMI -> DVI and Composite Audio?
By cactusPhone in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th May 2007, 22:32
