hi, im trying to encode with virtualdub.
my problem is that when im encoding 1 pass encode the subtitles are just as i set them in the textsub 2.3 filter.
when im encode 2-pass (xvid) the subtitles arent in the psition and the size ive set them in the filter :S
as i see it seems to be at the default size and position - iencode the 2-pass with *dont run this job now -> job control.
ive check now - when im running 2-pass encoding without job control its seems to be good.
what can be the problem?
tyvm![]()
Nope, no idea but try virtualdub forum, http://forums.virtualdub.org/
That's VirtualDubMod, no?*dont run this job now -> job control
I suggest you switch to virualdub if it is.
Set up job control for pass 1 and then pass 2.
THEN start job control (F4). -
im using virtualdub, one more little thing maybe im wrong with that - im setting the first pass job, and for the 2nd job i should use the original video right?
FWIW, I am often adding SOFT subtitles to xvid avi files using AviAddXSubs.exe. It is the only solution I have found that would let me stream files with soft subtitles on a PS3, and this application is extremely fast and works beautifully.
It may bother you to have another step in your process, but it's so fast that I don't see it as an issue.
Naturally, you need the srt text format for your subtitles. -
HowTo add permanent Letterboxed subtitles to video w/ Virtualdub, SRTtoSSA
By KneeRow in forum SubtitleReplies: 20Last Post: 13th Feb 2013, 14:05 -
Problem with Virtualdub
By pranjev in forum Newbie / General discussionsReplies: 25Last Post: 30th Dec 2011, 13:16 -
Subtitles not showing up in VirtualDub
By vaskimies in forum Video ConversionReplies: 2Last Post: 18th Jun 2011, 14:29 -
Hardcoding subtitles with VirtualDub
By sypolts in forum Newbie / General discussionsReplies: 5Last Post: 3rd May 2010, 07:44 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08
