Ive got software such as Super Dvd creator, Imgburn, and Dvdflick but before you burn avi files to disk they require converting or authoring.. I know windows media player DOESNT, what other software just burns files to disk without having to be converted? Its a pain beause with these programs it asks to search a folder for a vob file for example and wont let me just burn an avi file to disk
Help would be much appreciated. Thanks
	If you don't "convert"....it won't be DVD Video and won't be playable on a DVD player attached to your television.
 If you ARE looking to create a DATA DVD with just a bunch of AVI files burned to it....ImgBurn will create DATA DVDs very easily.
	If your DVD player can accept DIVX AVI on DATA Disks, just use any DVD/CD burning program to make a DATA CDs, and add the
 AVI... I recommend CDBurnerXP or IMGBurn (as Noahtuck recommended) to do this ....
 Just make sure your AVI's dimensions have DVD resolution (720x460,720x576, etc.....) and are in XVID or DIVX codec....
 Good luck
  Author/burn software which burns many mpgs in < time than Win DVD MakerBy wetcamelfood in forum Newbie / General discussionsReplies: 2Last Post: 9th Jul 2011, 12:09
  whats the best software to convert flv to aviBy videodude1966 in forum Video ConversionReplies: 1Last Post: 10th Feb 2011, 04:16
  dvd burning/convert program which burns both 4:3 and 16:9 for single movieBy vampelle in forum DVD RippingReplies: 7Last Post: 20th Sep 2010, 04:50
  Best avi to dvd software that burnsBy mol3000 in forum Video ConversionReplies: 1Last Post: 19th Aug 2010, 00:19
  Best software to convert avi to dvd???By Chana1 in forum Video ConversionReplies: 8Last Post: 1st Jun 2007, 09:42
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
