I have several avi files on 3 CDs. They are each between 100 and 250 MB. They are security video clips from Walmart (no sound). I tried to view them with
Quicktime - wouldn't load
Windows Media Player - wouldn't load
VLC - black screen but the timer loads correctly and runs
DivX Plus Player - black screen but the timer loads correctly and runs
Oxelon Media Converter - status comes up as error
GSpot 2.70a - Identifies file as AVI 1.0. Under Codec it says "SN40" and name "unknown" and status "Codecs are NOT installed"
Under proposed codec solutions and tests it says "Unable to render the video"
I am not experienced with any of these programs. I've just been bumbling along following what I can find online. Any help would be greatly appreciated.
Thanks!
Security camera manufacturers like to encode their videos in proprietary ways, for some reason (to make them harder to alter, perhaps?), and often, you'll probably need to check with the manufacturer for either a special viewer, or a codec. In this case, it sounds as though the videos are encoded with a proprietary video codec.
You can try running the videos through MediaInfo to get a little more information about them, but chances are, you'll need to at least see if the camera manufacturer has a player or codec on their website you can use (or failing that, contact them and see what you can do with the videos).If cameras add ten pounds, why would people want to eat them? -
Thanks for the input! Walmart tells me that they viewed the video through Videosphere Evidence Viewer which is apparently a program that is supposed to autorun the clips for third parties (law enforcement, etc...). They also supposedly downloaded the player along with the videos on the cds. However, when I open the CD in explorer all I see is the three video clips which now have the Quicktime icon on them. Any suggestions?
Videosphere:
http://www.structuredweb.com/sw/swchannel/CustomerCenter/documents/4345/7191/VisualIntelligence.pdf
Thanks,
Chris
AVI file from Nikon camera won't play in WMP.
By frankmaster100 in forum Newbie / General discussionsReplies: 6Last Post: 27th Dec 2010, 20:02 -
AVI file won't play via stand alone DVD player
By 3lutz3toe in forum MacReplies: 2Last Post: 24th Dec 2009, 05:37 -
WMP 10 won't play avi with subtitle file.
By zlmdlo in forum Software PlayingReplies: 1Last Post: 14th Dec 2009, 04:22 -
AVI file won't play back
By Clydesdale in forum Software PlayingReplies: 9Last Post: 3rd Apr 2008, 23:22 -
AVI File Burned to DVD won't play ?
By DuBsTaR in forum Newbie / General discussionsReplies: 7Last Post: 24th May 2007, 20:20
